0.109: New integrations page and weather card, frontend lost weight
Xiaomi sensors via deconz
If not language, then perhaps the card you are using. For example, I’m using the standard entity card and it correctly shows Open/Closed for doors and Detected/Clear for motion.
Hi Fabio,
Yes I could read that, but it just shows an example beneath that looks like it is still possible to implement this manually?
Very fair, I just tested. I will seek in this direction. Thank you.
The problem is from lovelace-multiple-entity-row
Yes, but not anymore in sensor, it’s in config now
ok thanks Franck, good to know this is as intended. Though persons is a bit surprising talking about Z-wave :wink:
and still listed:
and I can reload them, just like the zones, which aren’t listed btw, and not available on the system either:
one more ‘anomaly’: Sonos can’t be dismissed and upon each restarts is being discovered and notifying persistently:
Not all reload capabilities are available via the UI yet. This is an open issue/task.
However, the reload services are available.
Person can be loaded up as a dependency of: default_config, device_sun_light_trigger, mobile_app or onboarding
(Please note, that those in their turn can be a dependency of another integration)
That will be addressed in 0.110, where we changed a large part of the way discovery works. Furthermore we have enforced ADR-0011, which requires discovered items to be ignorable.
sorry, you’re right, and I should have mentioned I dont have these setup, my configuration.yaml is edited manually.
So maybe only ‘onboarding’ would cause the integration to be there, though one wouldn’t expect that.
Maybe some short explanation I this regards could be added to the main docs, stating integration to be listed/used, without actual devices/entities of that integration being alive on the system.
I’m not sure what the added value of that would be. But that is a personal opinion.
Okay - thanks man!
well, if I may, a listing is of value if the people checking the list understand its workings. Ive long had a python script and templates showing me which integrations and components live on my system.
I was pleasantly surprised when this started to become available in Ha by default. Now this list is also starting to show other integrations I dont use, have installed, or even recognize to be related to my system, the whole list is becoming more of a mystery to me than it is of added value…
A small explanation could mitigate that :wink:
example from my main system, showing only available items:
Just updated and my tellstick wont load anymore… Service calls seem to be working though. I get current values in the log when I fetch sensors. I get this:
Log Details (ERROR)
Logger: homeassistant.setup
Source: components/tellstick/__init__.py:112
First occurred: 5:34:17 PM (1 occurrences)
Last logged: 5:34:17 PM
Error during setup of component tellstick
  File "/usr/src/homeassistant/homeassistant/setup.py", line 175, in _async_setup_component
    component.setup, hass, processed_config  # type: ignore
  File "/usr/src/homeassistant/homeassistant/components/tellstick/__init__.py", line 112, in setup
    tellcore_devices = tellcore_lib.devices()
  File "/usr/local/lib/python3.7/site-packages/tellcore/telldus.py", line 173, in devices
    count = self.lib.tdGetNumberOfDevices()
  File "/usr/local/lib/python3.7/site-packages/tellcore/library.py", line 257, in check_int_result
    raise TelldusError(result)
tellcore.library.TelldusError: Could not connect to the Telldus Service (-6)
I just installed 0.109.1
Broadlink for my broadlink M3 mini is working again
Integrations do not have to provide entities…
My Tellstick-issue was resolved when I removed the deprecated unifi-component from my yaml. I understand that it is configured through the UI now. Dont understand why it disturbed the tellstick component tho. Anyways, happy now :slight_smile:
Does it even go through configuration validation? When I added this in the same format as you did, i got error message after validation:
Invalid config for [synology_dsm]: [platform] is an invalid option for [synology_dsm]. Check: synology_dsm->synology_dsm->2->platform. (See /config/configuration.yaml, line 573).
So I did used the old format, just changed integration name to new:
  - platform: synology_dsm
    host: 192.168.52.21
    username: xxxx
    password: yyyy
but this does not seem to work, both my units seem to be discovered, but only one goes through complete configuration process.
BTW I’m not sure if all of your options are valid for changed integration. According to documentation now only host, port, ssl, username, password, volumes, disks are valid options and monitored_conditions are discarded…
Its not just tuya covers, I am using MQTT cover and I have the same problem - up/down arrow greyed out.
It doesn’t matter if I set optimistic mode true/false or whether I use state topic or not, up and down arrow are always greyed out.
