ha core update --version=0.108.9
EDIT, dang. Too slow.
yes it did, depending on your weather integration.
Iâve long ago tried to start a discussion about that, but it was never picked up. Installed another weather integration to be sure it wasnât sunny at night
I posted earlier this. seems that only me have this problem?
can you check it somehow?
Synology integration cannot be configured for multiple devices.
I have 2 devices, one physical and one virtual. Both properly recognized after installation of 0.109. I started with configuration of physical one and it went smoothly (well, again all sensors I used changed names). Then I tried to configure second one, virtual and it hangs indefinitely on configuration screen with spinning wheel⌠I tried few times, even restarted HA in meantime, but always with the same result. Same if trying secure or insecure connection or different users. It seems to go through authentication though, since if I enter wrong user/password combination I instantly get error message.
Why me?. I donât have any covers and Iâm not on 0.109 yet.
Thatâs ok no worries. You are always so helpful to everyone thatâs why I asked from you.
Eventually someone we resolve it. I downgraded to 0.108.9 and I am ok for the time being.
I just liked so much the 0.109 because it was very fast. I will upgrade in a later version I guess
Thanks!
After updating to 0.109.0 the postgesql sensor failed:
Couldn't connect using postgresql://username:[email protected]:5433/database DB_URL: (psycopg2.errors.UndefinedObject) unrecognized configuration parameter "wait_timeout" (Background on this error at: http://sqlalche.me/e/f405)
Anyone seen this before?
(this is the sensor: https://www.home-assistant.io/integrations/sql/#database-size-in-postgres)
So if youâve changed a bunch of the entities names you loose them?
yes.
I didnât say it made sense.
Itâs happened to me several times using the Unifi integration. I eventually got smart and made sure I named the devices in the controller the same as I wanted them in HA so I wouldnât need to keep renaming them every time I needed to clear out all of the unwanted entities by deleting then re-adding the integration because we arenât allowed to delete them thru the UI. But thatâs another storyâŚ
With the latest release unifi integration will try to clean up all registries when changing options that will remove entities e.g. Donât track wired clients will remove all affected entities and their references in entity and device registry
Ditto. Do you know what they are talking about with this purge option?
Couple of issues for me;
I canât delete the integration from the UI.
I currently have in my config. Do I need this?
isy994:
host: !secret isy_host
username: !secret isy_username
password: !secret isy_password
If you have this line in your configuration.yaml file (under recorder:
purge_interval: 1 # or any other number of days
Delete it.
Purging will occur every night by default.
You only posted your 1st message 2 hours ago, sit back, relax & wait.
FYI - https://github.com/home-assistant/core/issues/34932
- https://github.com/home-assistant/core/issues/34939
Thanks for your hard work BTW
Does broadlink.send works for anyone on 0.109 with RM4C mini
It should have an icon. Without that it could for example be Netatmo.
Problem with new FritzBox 7530 auto-descovery:
lost states:
states.sensor.fritzbox.attributes.transmission_rate_down
states.sensor.fritzbox.attributes.transmission_rate_up
in yaml mode this appears.
Moreover, Fritz Repeater 1750E (mesh) have been found but after login there is no integration possible, with message:
Aborted:
âConnected to AVM FRITZ!Box but itâs unable to control Smart Home devices.â
I have reverted fritz in yaml mode for now.
Hi Makis, Iâm having the same issue here with a tuya curtain switch (used for my sunscreen). For some reason it never showed the correct state (open/close) in previous releases as well, however in those I was able to press all buttons whereas now you can only press stop which doesnât do anything.
Edit: btw also running hassio in a NUC though donât think that is related?
