I’m getting this error after I grant access:
500 Internal Server Error
Server got itself in trouble
I see this in the logs:
Logger: aiohttp.server
Source: helpers/config_entry_oauth2_flow.py:167
First occurred: 7:53:27 AM (2 occurrences)
Last logged: 7:53:44 AM
Error handling request
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py”, line 418, in start
resp = await task
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py”, line 458, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py”, line 119, in impl
return await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/real_ip.py”, line 39, in real_ip_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 73, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 127, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/view.py”, line 125, in handle
result = await result
File “/usr/src/homeassistant/homeassistant/components/config/config_entries.py”, line 136, in get
return await super().get(request, flow_id)
File “/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py”, line 91, in get
result = await self._flow_mgr.async_configure(flow_id)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 153, in async_configure
result = await self._async_handle_step(flow, cur_step[“step_id”], user_input)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 201, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File “/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py”, line 248, in async_step_creation
token = await self.flow_impl.async_resolve_external_data(self.external_data)
File “/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py”, line 142, in async_resolve_external_data
“redirect_uri”: self.redirect_uri,
File “/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py”, line 167, in _token_request
resp.raise_for_status()
File “/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py”, line 946, in raise_for_status
headers=self.headers)
aiohttp.client_exceptions.ClientResponseError: 400, message=‘Bad Request’, url='https://api.home-connect.com/security/oauth/token
