Is there any reason why I would not be getting Release 0.112.5 - July 14?
My last update was 0.112.4 which came over and updated successfully.
What is your installation type? If it’s Docker, HassOS, or anything other than Core (or Core in a venv) 0.112.5 isn’t and won’t be made available. 0.113 should be out tomorrow with the same fixes.
Not the OP, but I had been wondering the same thing, must have missed that note.
I had noticed:
20-07-21 12:32:40 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json: in my logs.
And this is the contents of that json, showing the latest version being .4
"channel": "stable",
"supervisor": "229",
"homeassistant": {
"default": "0.112.4",
"qemux86": "0.112.4",
"qemux86-64": "0.112.4",
"qemuarm": "0.112.4",
"qemuarm-64": "0.112.4",
"intel-nuc": "0.112.4",
"raspberrypi": "0.112.4",
"raspberrypi2": "0.112.4",
"raspberrypi3": "0.112.4",
"raspberrypi3-64": "0.112.4",
"raspberrypi4": "0.112.4",
"raspberrypi4-64": "0.112.4",
"tinker": "0.112.4",
"odroid-c2": "0.112.4",
"odroid-n2": "0.112.4",
"odroid-xu": "0.112.4"
"hassos": {
"ova": "4.11",
"rpi": "4.11",
"rpi0-w": "4.11",
"rpi2": "4.11",
"rpi3": "4.11",
"rpi3-64": "4.11",
"rpi4": "4.11",
"rpi4-64": "4.11",
"tinker": "4.11",
"odroid-c2": "4.11",
"odroid-n2": "4.11",
"odroid-xu4": "4.11",
"intel-nuc": "4.11"
"hassos-cli": "19",
"cli": "25",
"dns": "9",
"audio": "16",
"multicast": "2",
"image": {
"core": "homeassistant/{machine}-homeassistant",
"supervisor": "homeassistant/{arch}-hassio-supervisor",
"cli": "homeassistant/{arch}-hassio-cli",
"audio": "homeassistant/{arch}-hassio-audio",
"dns": "homeassistant/{arch}-hassio-dns",
"multicast": "homeassistant/{arch}-hassio-multicast"
It was mentioned in the .112 release thread, but was a wee bit buried ;-).
