I had to reinstall a couple of my cards from hacs.
Hi
after upgrading to 0.112.x I noticed a delay, sometimes very long, for MQTT messages.
I’ve always had the Mosquitto Broker addon and it’ was working fine before.
What can I check?
I alone am not happy with the 0.112 update. Now I can’t use the custom_components xiaomi_aqara for my converted motion sensors, a trigger time every 12 seconds. Why didn’t you leave the possibility of the old configuration? Now I can not update HA’
My database is 3.2Gb. It is running mariadb in docker on the same machine as ha core (also in docker). It is a nuc. Intel® Core™ i5-5250U CPU @ 1.60GHz. 8G ram.
There is no aqara relay support again (
why not wait for the author to update the custom component or ask them to update it?
My Xiaomy Awara Gateway didnt connet on 0.112.
- Comment out in configuration.yaml xiaomi_aqara.
- Xiaomi Aqara Gateway does not show up automatically.
- Trying to add with xiaomi_aqara Integrations.
- Didnt find it.
xiaomi_aqara host: 192.168.1.40
HA host: 192.168.2.34
And they connet to different routers.
P.S. “Xiaomi Miio: Gateway” integration see my gateway…
Instead of any
for network interface on the integration screen try the IP for the device HA is running on.
Same here. I have had to update from the command line since 0.110.
I was talking about the update binary sensor.
’ve been experiencing issues with the the Lutron Caseta after upgrading to 112, my occupancy sensors are no longer detected. They were working fine on 111.4. I tried removing the integration and reinstalling and nothing. The lights work fine, in HA and the app, the sensors only work on the app.
Error while setting up lutron_caseta platform for binary_sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 186, in _async_setup_platform
await asyncio.gather(*pending)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 292, in async_add_entities
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 343, in _async_add_entity
device_info = entity.device_info
File "/usr/src/homeassistant/homeassistant/components/lutron_caseta/__init__.py", line 134, in device_info
"identifiers": {(DOMAIN, self.serial)},
File "/usr/src/homeassistant/homeassistant/components/lutron_caseta/__init__.py", line 123, in serial
return self._device["serial"]
KeyError: 'serial'
Ive skimmed through these posts but haven’t seen anyone asking if its possible to disable the frontend refresh. it seems to be messing with my RSTP camera streams. RSTP stream hasnt been the greatest but now its pretty unusable …Hope someone can help thanks
update to 0.112.1 and check the user profile on the device to disable the refresh
Yep same here - Xiaomi Air Purifiers have stopped working
Hi Yoinkz, i have added three aqara gateways in HA and they work without a problem.
I have problems with xiaomi philips light bulbs. After update to 0.112 they are not visible to HA, and they work normal in Mihome app. I even did reset one of the lamp for new token, but again no success.
Any ideas?
Thank you
BR
I tryed, but this dont work for me.
So you are across different subnets. Perhaps the new config method doesn’t support that?
Router 1 -> Router 2(lan) -> HA Pi3b+(lan)
Router 1 -> Xiaomi Gateway(WiFi)
I really like how fast history and logbook are after upgrade ! I do not like though the default settings that are applied to views Every time I check history I have to reconfigure view from calendar selector to see exactly what I want to see.
Would it be possible to have some sort of default view configuration paramenetrs in history component to be added? Sort of:
default_view:
show: 24 h # number of hours to show
2 d # number of days to show
start: flex # start at exact number of hours/days back from now()
day_start # start at midninght of first full inclusive day
So the old behaviour from pre 0.112 (show up to 24 hours from midnight) would be then configured as:
default_view:
show: 24 h
start: day_start
and my preferred view (show last 48 hours) would be:
default_view:
show: 48 h
start: flex
Obvioulsy just an idea, actual implementation could be done perhaps somehow smarter…
HIYerum, how did you fix the Toon Call back url issue? I can´t make it work with mine…
Thanks,
