Basically an Ubuntu docker install.
So Ubuntu 18.04.and then
curl -sL https://raw.githubusercontent.com/home-assistant/hassio-installer/master/hassio_install.sh | bash -s
And you already know I have mariadb.
So i restored from backup again a different one and still no joy. Different issues but maybe that’s due to a upgrade from an “older” version. 0.110. Basically same outcome.
2020-07-06 05:47:52 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-07-06 05:47:52 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-07-06 05:47:52 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for audiconnect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-07-06 05:47:52 WARNING (MainThread) [homeassistant.components.http] The 'base_url' option is deprecated, please remove it from your configuration
2020-07-06 05:47:52 WARNING (Recorder) [homeassistant.components.recorder.migration] Database is about to upgrade. Schema version: 7
2020-07-06 05:47:52 WARNING (Recorder) [homeassistant.components.recorder.migration] Adding columns context_parent_id to table events. Note: this can take several minutes on large databases and slow computers. Please be patient!
2020-07-06 05:47:52 WARNING (Recorder) [homeassistant.components.recorder.migration] Column context_parent_id already exists on events, continuing
2020-07-06 05:47:52 WARNING (Recorder) [homeassistant.components.recorder.migration] Adding columns old_state_id to table states. Note: this can take several minutes on large databases and slow computers. Please be patient!
2020-07-06 05:47:52 WARNING (Recorder) [homeassistant.components.recorder.migration] Column old_state_id already exists on states, continuing
2020-07-06 05:47:52 WARNING (Recorder) [homeassistant.components.recorder.migration] Adding index `ix_events_context_parent_id` to database. Note: this can take several minutes on large databases and slow computers. Please be patient!
2020-07-06 05:47:52 WARNING (Recorder) [homeassistant.components.recorder.migration] Index ix_events_context_parent_id already exists on events, continuing
2020-07-06 05:47:52 WARNING (Recorder) [homeassistant.components.recorder.migration] Failed to drop index ix_states_context_id from table states. Schema Migration will continue; this is not a critical operation.
2020-07-06 05:47:52 WARNING (Recorder) [homeassistant.components.recorder.migration] Failed to drop index ix_states_context_user_id from table states. Schema Migration will continue; this is not a critical operation.
2020-07-06 05:47:52 WARNING (Recorder) [homeassistant.components.recorder.migration] Failed to drop index ix_states_entity_id from table states. Schema Migration will continue; this is not a critical operation.
2020-07-06 05:47:52 WARNING (Recorder) [homeassistant.components.recorder.migration] Adding index `ix_events_event_type_time_fired` to database. Note: this can take several minutes on large databases and slow computers. Please be patient!
2020-07-06 05:47:52 WARNING (Recorder) [homeassistant.components.recorder.migration] Index ix_events_event_type_time_fired already exists on events, continuing
2020-07-06 05:47:52 WARNING (Recorder) [homeassistant.components.recorder.migration] Failed to drop index ix_events_event_type from table events. Schema Migration will continue; this is not a critical operation.
2020-07-06 05:47:52 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (MySQLdb._exceptions.IntegrityError) (1062, "Duplicate entry '0' for key 'PRIMARY'")
[SQL: INSERT INTO schema_changes (schema_version, changed) VALUES (%s, %s)]
[parameters: (9, datetime.datetime(2020, 7, 6, 10, 47, 52, 627688, tzinfo=<UTC>))]
(Background on this error at: http://sqlalche.me/e/gkpj)
2020-07-06 05:47:52 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.IntegrityError) (1062, "Duplicate entry '0' for key 'PRIMARY'")
(Background on this error at: http://sqlalche.me/e/gkpj) (retrying in 3 seconds)
Then it just keeps repeating that for a while. Should note this is the same error the first time I ran this upgrade after the restore and does this every time after that.
Should note before doing the upgrade after restore this time I increased the drive space in case it was trying to use more than 4GB of space to do the DB changes so have like 80GB free now.
