0.113: Automations & Scripts, and even more performance!
Yes, same here. More than 20 minutes to restart. Not experienced in 0.112.4 (2 minutes to restart)
Iā€™ve got a denkovi maxi I/O
The reason I went for this is that it has 8 relay channels and 4 analog temperature inputs and wired network connection. I use it to control my heating and ventilation system and wanted it to be all hard wired. Iā€™m a sparky so didnā€™t mind having to pull a few wires around the place.
I never intended it to be able to take a switch input but that was just an added bonus!
I only have one switch being polled on it.
This being said Iā€™ve got a wi fi dimmer on the way so it will probably become redundant soon!
Installation of 0.113.2 failed badly on my pi 3.
This is output after I updated from 0.112.2 to 0.113.2:
>sudo systemctl status home-assistant@homeassistant
Jul 29 21:19:33 hassbian hass[743]: 2020-07-29T21:19:33+0200 Info: Connected to 192.168.0.201
Jul 29 21:19:37 hassbian hass[743]: 2020-07-29T21:19:37+0200 Warning: No dispatcher found for notification
and later I get these:
Jul 29 21:21:03 hassbian hass[743]: 2020-07-29T21:21:03+0200 Warning: InvokeId mismatch: waiting for 0x16 received 0x11
Jul 29 21:21:03 hassbian hass[743]: 2020-07-29T21:21:03+0200 Warning: No response pending
Jul 29 21:21:03 hassbian hass[743]: 2020-07-29T21:21:03+0200 Warning: InvokeId mismatch: waiting for 0x16 received 0x12
Jul 29 21:21:03 hassbian hass[743]: 2020-07-29T21:21:03+0200 Warning: InvokeId mismatch: waiting for 0x16 received 0x13
Jul 29 21:21:03 hassbian hass[743]: 2020-07-29T21:21:03+0200 Warning: InvokeId mismatch: waiting for 0x16 received 0x14
Jul 29 21:21:03 hassbian hass[743]: 2020-07-29T21:21:03+0200 Warning: InvokeId mismatch: waiting for 0x16 received 0x15
HA is not loading in the browser anymore. Reboot of my pi does not help. I reverted to 0.112.4
Anything I could try?
Same hereā€¦ I was going crazy thinking to what was causing thisā€¦
Do you have spotcast installed?
Yes, I have spotcast on its latest version (3.3.5) both configured and running in my Home Assistant, but never experienced a slowdown issue with it until 0.113.
On 0.113 while running the top command on the host I noticed that python3 kept going through the roof, eating over 150% CPU and Time+ going over 300:xx.0 sending the 15 minute load average around 15.x, when on 0.112.x CPU usually remained below 15%.
I read on the opened issues you mention that spotcast has been spotted as a possible related factor. Hopefully it will get fixed with 35943 or a spotcast update.
Thank you! :smiley:
Did you manage to keep your device names as they were before migration?
Yes but not easy:
  1. take care you prepare your configuration.yaml before upgrading, remove name field and add a # with the orignal name.
  2. upgrade
  3. go to entities and search on the rfx idā€™s in your configuration.yaml, you will find them and then you can rename them to the original names so all your automations etc will work again without modifying.
Still is present/not fixed in 0.113.3 0.113.2
Very annoying because I use(d) this function a lot :tired_face:
Where is 0.113.3?
Good question :sweat_smile: So still a chance to get it fixed actuallyā€¦
trying to work out the already reported issues with google tts notifications, I now notice all my notify.notify services stopped working after updating to 113.2.
this is in the log if I issue a service manually from the developer-tools/service
2020-07-30 17:56:28 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found.
2020-07-30 17:56:29 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found.
2020-07-30 17:56:30 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found.
which is silly because notify.notify has nothing to do with my registered mobile apps, and I am not issuing that command in the first placeā€¦
so, checking that in the services page, I now am scattered to see none of these mobile_app services work eitherā€¦?
hope I am not aloneā€¦
is this a(nother) bug?
ha core update --version 0.113.1
restores the earlier mentioned tts %20 issue, but I still have issues with the services page using notify.notify and other notification groups. Pushbullet still works fine, the others give the posted error still
Thereā€™s an issue with mobile push at the moment:
o Iā€™ve missed that, sorry. Thanks for the link, this is a major bummerā€¦
coming to think of it, Ive also updated the iOS app yesterday. Hope this isnt a chain of issues ;-(
update
found my older iPhone and iPad and they did receive the notificationsā€¦is it the new app then after all?
I was able to update last night but for some reason I canā€™t log in when using my normal Firefox session. If I open it in Firefoxā€™s Incognito Mode, I can log in fine. If I use Chrome, it also works fine.
When I log in through the regular session I get 400 errors for the /token endpoint and thereā€™s errors in the JS console.
Uncaught (in promise) TypeError: u.addEventListener is not a function
    e core.a99cac39.js:1
    o core.a99cac39.js:1
    hassConnection core.a99cac39.js:1
    promise callback*196 core.a99cac39.js:1
I cleared the entire cache and also tried by using Firefox in safe mode and it still doesnā€™t work. Not sure why Incognito would work fine though.
Update to this issue: I forced Firefox to start in Safe Mode, and was able to get back in with my regular browser session. The Firefox extension I had installed (WebSocketSniffer) was messing up the websocket connection.
anyone else seeing this weird behavior from 0.113?
Capture
I thought my logs were broken but it really is empty after +24h!
Nice work guys!!!
Iā€™m having the ā€œrequested entity not foundā€ issue too.
Just commenting to say, you guys are awesome! I just got around to checking out the 113 notes and the automation & scripts updates are much, much appreciated. As someone whoā€™s innermost thoughts are comprised of about 50% functional programming code, having the ability to do loops and if/else syntax makes writing up new automations SO MUCH EASIER. Iā€™ve only been messing with HA for about 4 months now and the progress Iā€™ve seen just in that time is unreal, and well worth my support (through HA Cloud subscription).
Keep up the fantastic work!
so are most people on the new iPhone Appā€¦ check this for development of the issue and hopefully quick fix
for now, resetting your push_id in the app settings makes the notifications work again (though no promises are made for how long)
Maybe you should check your IP-Bans?
