hi
could someone help on this please? tried again with 0.113.2 again today again same issue… all my GH mini are unavailable post upgrade
hi
could someone help on this please? tried again with 0.113.2 again today again same issue… all my GH mini are unavailable post upgrade…
I just upgraded (somewhat successfully) to 0.113.3. I see changes Kodi and an update to pynws, both of which I use – and startup will now finish. I’m not sure how these were found as I never got any warning or error in logs (even with core debug on)… Nice!
EDIT: The icon issue below appears to just be a browser cache (or something like that) issue. Opening in a different browser, no issues.
I still have a few issues with icons. For distinguishing people I use different versions of mdi:human – so mdi:human-male, mdi:human-female, mdi:human-handsup, etc. None of these icons show up – is this a mistake or intentional? This can be replicated in the UI in any of the panels allowing customization within the UI). The issue may not be limited to these as I have a few other spots that appear blank. Is there any way to view the list of icons that should be included in the release?
I don’t want to open an issue until proven that it won’t fix itself after a restart, or if it’s some other config issue I have remaining.
They’re all included, for now. The ones you have to update are listed in your log.
HELP!
When I upgraded from 0.113.1 to 0.113.2 it killed my server. All I could get was a 502 Bad Gateway error from nginx. I eventually managed to restore a snapshot and get everything back to where it was.
I decided to wait till 0.113.3 and it has done exactly the same thing, my log file has shrunk to 2kb and show this:
2020-08-01 19:50:24 ERROR (MainThread) [root] Uncaught exception
File "/usr/local/lib/python3.8/runpy.py", line 194, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/local/lib/python3.8/runpy.py", line 87, in _run_code
exec(code, run_globals)
File "/usr/src/homeassistant/homeassistant/__main__.py", line 320, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 312, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 119, in run
return asyncio.run(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.8/asyncio/runners.py", line 43, in run
return loop.run_until_complete(main)
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 616, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/runner.py", line 108, in setup_and_run_hass
hass = await bootstrap.async_setup_hass(runtime_config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 107, in async_setup_hass
config_dict = await conf_util.async_hass_config_yaml(hass)
File "/usr/src/homeassistant/homeassistant/config.py", line 313, in async_hass_config_yaml
await merge_packages_config(hass, config, core_config.get(CONF_PACKAGES, {}))
File "/usr/src/homeassistant/homeassistant/config.py", line 711, in merge_packages_config
error = _recursive_merge(conf=config[comp_name], package=comp_conf)
File "/usr/src/homeassistant/homeassistant/config.py", line 640, in _recursive_merge
error = _recursive_merge(conf=conf[key], package=pack_conf)
File "/usr/src/homeassistant/homeassistant/config.py", line 648, in _recursive_merge
if conf.get(key) is not None:
AttributeError: 'NoneType' object has no attribute 'get'
I have run Check Config and it came back clear against 0.113.3
Any help would be greatly appreciated
Can I request; When a new version comes out that there is a hyperlink at the TOP of the page that links to the new builds, so you click it and it takes you to the bottom of the page where the information/fixes of that build is listed? Will save on scrolling
Anybody else having trouble adding devices to ZHA since 0.113.2 upgrade?
Actually I was right with this even before 0.113.3 was released. Still broken in 0.113.3.
Sorry to spam here but I was “removed” from participating in the home assistant github because asking for more inclusion for the android app.
Hello I just updated to 0.113.3 and it changed the states of my automations from Off to ON. Was this intended?
Unfortunately I don’t see any entries in IP-Bans. I don’t think the IP ban would apply if I can access it successfully from the same IP address but a different browser, would it?
Update to this issue: I forced Firefox to start in Safe Mode, and was able to get back in with my regular browser session. After restarting it to be out of Safe Mode the fix sticks and works properly.
So you keep saying. It is getting repetitive and tedious.
reduce the debug level down to error.
Can anybody help me understand what’s causing such behaviour:
This code works fine:
sunrise:
alias: Sunrise
mode: single
sequence:
- repeat:
sequence:
- data:
brightness_step: 2
entity_id: light.sonoff
service: light.turn_on
- delay:
seconds: 1
until:
- condition: template
value_template: '{{ repeat.index >= 124 or states.light.sonoff.state
== ''off''}}'
And this one stops after one pass:
sunrise:
alias: Sunrise
mode: single
sequence:
- repeat:
sequence:
- data:
brightness_step: 1
- delay:
seconds: 1
until:
== ''off''}}'
It would seem that the 0.113 update moved python to version 3.8. and there’s not wheel file available for tensorflow 1.13.2 and python 3.8. to use python3.8, you need to upgrade to tensorflow 2.2 or above.
i’m looking into options… perhaps a manual downgrade to python3.7 is possible on docker. cant seem to find the apt program so things are proving a little more difficult.
If you are on docker then within the home assistant container there is no apt. Why would there be? The container is based on alpinelinux, which uses a different packaging system.
Has anyone else noticed that CPU utilisation tends to ramp up with time since the 0.113 update?
It’s not much (on my overspeced system) but is completely different to the level average utilisation I was seeing on 0.112 and earlier.
I found this to be caused by the fact that my card is an entity in an entities card. Using the Airvisual card stand alone works fine
- type: entities
entities:
- !include /config/lovelace/includes/include_aqi_woensdrecht.yaml
- type: custom:auto-entities
card:
type: entities
style: |
ha-card {
box-shadow: none;
margin: 0px -16px -26px -16px;
title: Air quality
show_empty: false
filter:
include:
- entity_id: '*.luftdaten*'
- entity_id: '*.u_s_*'
- entity_id: '*.chinese_*'
- entity_id: 'air_quality.*'
- type: custom:fold-entity-row
head:
type: section
label: More Waqi info
entities:
card:
type: entities
style: |
ha-card {
box-shadow: none;
margin: 0px -16px 0px -36px;
show_empty: false
filter:
include:
- entity_id: 'sensor.waqi*'
exclude:
- state: '-'
wonder where the bug/issue lies, with the Airvisual card or with Lovelace…of course it could also be a user error
There have been some reports I think. Can’t find them right now. Symptoms included lock up and/or crippling slow down on lesser systems like pis.
Hi, where I can read info about that? I also have that problem, the use of the cpu goes up and ends up blocking
