As you may have heard 0.113 included a revolutionary logic mechanism called “chooser”. It occurred to me that this could be a “better” way to handle multiple events, such that happens with scene buttons.
For example I have a Xiaomi switch which has two buttons built in. It can product the following events: left_single, left_double, right_single, right_double, both_single, both_double
. Up until version 0.113 we could only accomplish this by using service_templates
and data_templates
and some complex template code. While I am proud of the solution I came up with, it always takes me time to wrap my head around it when I haven’t looked at the code in a while. The new “chooser” version I created may be longer, and perhaps less elegant, but I believe the purpose of the code will be clear quickly every time I revisit the code.
Pre-0.113 Template version
- service_template: >
{%- set clicks = trigger.event.data.command.split('_')[1] %}
{%- if clicks == "double" -%}
switch.toggle
{%- elif clicks == "single" -%}
light.toggle
{%- endif %}
data_template:
entity_id: >
{%- set side = trigger.event.data.command.split('_')[0] %}
{%- set button_press = {
"left": {
"single": "light.bedroom",
"double": "switch.sound_machine"
"right": {
"single": "light.brian",
"double": "switch.bedroom_fan"
"both": {
"single": "light.bedroom_table_lamp",
"double": "switch.sound_machine, switch.bedroom_fan"
{{ button_press[side][clicks] }}
Post 0.113 Choose version
# Bedroom Double Switch
- conditions:
- condition: template
value_template: "{{ trigger.event.data.device_ieee == '00:15:8d:00:02:83:e2:b6' }}"
sequence:
choose:
# Single Click: Left
- conditions:
value_template: "{{ trigger.event.data.command == 'left_single' }}"
sequence:
- service: light.toggle
entity_id: light.bedroom
# Single Click: Right
- conditions:
value_template: "{{ trigger.event.data.command == 'right_single' }}"
sequence:
entity_id: light.brian
# Single Click: Both
- conditions:
value_template: "{{ trigger.event.data.command == 'both_single' }}"
sequence:
entity_id: light.bedroom_table_lamp
# Double Click: Left
- conditions:
value_template: "{{ trigger.event.data.command == 'left_double' }}"
sequence:
- service: switch.toggle
entity_id: switch.sound_machine
# Double Click: Right
- conditions:
value_template: "{{ trigger.event.data.command == 'right_double' }}"
sequence:
entity_id: switch.bedroom_fan
# Double Click: Both
- conditions:
value_template: "{{ trigger.event.data.command == 'both_double' }}"
sequence:
entity_id:
- switch.sound_machine
- switch.bedroom_fan
