Hmm upgraded tot 0.114 and now I get the message on startup ‘Invalid config’. However a ‘check config’ concludes that the configuration is valid… It cannot not load:
default_config
Default_config is in de configuration since I started with HA. The other two components are not specifically configured. In the breaking changes I do not see anything that would be related to my setup except for Evohome. But no action would needed there. So I am in the dark as to how I should fix this problem. Does anyone have an idea?
It is failing on line 81 during initial setup of devices. That appears to be a bug and probably should be reported as an Issue in the Core repository. In case I’m wrong, you may want to wait a day or two for other Control4 users to report their experiences.
Thnx for the suggestion moving the (sqlite) database did the trick. The improvement that the database would be reset when there are troubles during booting doesn’t seem to work in this case. However I am happy that I can use HA again and in general I am really really happy with HA.
The trick is to (re)move your database that is under /config/home-assistant_v2.db. With a Home Assistant installation with supervisor you can install/use the file editor to complete this and then restart Home Assistant.
The cause seems to be loading big recorder databases that take over 300 seconds to load from the log. However in previous versions starting Home Assistant even with a database as big didn’t seem to take that long. Hopefully te issues is a onetime thing and vanishes now otherwise I will have to dig a lot deeper.
When opening a entity (lovelace ui) from the “related” tab from another entity it is not possible anymore to open the settings (wheel top right on the entity window) and see other related enteties for example.
Same here, just the line "default_config:" doesn't allowed to load the add-ons... And I don't want to move the DB, actually I don't even know how to do it :( .
