have you find the answer? also, what are the configurable options for this card?
This release has fixed by biggest problem Iāve had. Insteon (actually x10) was my starting point into Smart Home and that was about 10 years ago. Home Assistant had been seeing 7 of my 11 Motion Sensors and 13 of my 14 Dimmer Switches. I love Insteon and these other devices have worked correctly through the Home Assistant, but 5 of them just wouldnāt join the gang for the fun.
On this new release now when I add them through the Device Override, theyāve now joined the crew and are working with all their brothers and sisters. I want to offer my thanks and appreciation to TEHarris. Iāve watched the work heās done on GitHub to help mature Insteon in the Home Assistant environment. Thatās no small challenge, given how peculiar and picky Insteon can be. Insteon always plays well with itself, but many times doesnāt like to play well with others.
Thanks for all your hard work TEHarris, itās really appreciated!
Iām wondering if some time-based sensor update confusion/complexity could be mitigated by borrowing scan_interval:
from Command Line Sensor for updating entity-less sensors.
This would avoid the complexity of requiring simple interval-based automations as a trigger, at least as described in Templates.
You could set static IPs for your phones instead of using reserved IPs on the router. Then your phone just declares what IP itās going to use and will always use that one. Typically youād do this outside the range your DHCP server is assigning IPs, but it has to be within the same subnet.
try removing the dot after states:
{{ states | count }}
Thanks, this was just a test, the question is, why does HA log it as an error, if the template tool is just for evaluating templates?
I agree. Seems unnecessary
Oh OK. Didnāt get that.
But from what Iāve read that is an expected behavior to log errors from the template editor now.
But I think I remember seeing something about a āfixā to suppress those errors being in the works.
That would be very helpful, especially for noobs like me.
Did you manage to get this working? Still not working for me on 115.2.
Yea Iāve just tried it over wifi to the nabu casa URL in Chrome Android and the same issue.
Iāve also tested in Windows Chrome and the same but it doesnāt crap out completely. It feels like a Nabu Casa issue, maybe bandwidth with all the streaming going via the proxy?
Another problem is this error in the log when connecting locally to HA on Android app and playing via the media browser:
Login attempt or request with invalid authentication from G8S-ThinQ (192.168.x.x) (Mozilla/5.0 (Linux; Android 10; LM-G810 Build/QKQ1.200614.002; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/85.0.4183.127 Mobile Safari/537.36)
The playback stopped after 5 seconds and I was unable to resume it. Every time I clicked on the play it started from beginning and stopped again.
EDIT: The second error maybe due to a corrupt recording I was trying to play. Iāve raised a ticket with Nabu Casa and theyāve come back and said thereās a 2mb throughput limit! News to me.
OTOH I can see value if an error message tells you something about why your template fails.
Definitely. That info should just be shown on the template editor window though
I think this would be very helpful
Yep. Thatās the only place itās even usefulā¦
Iād like to add my vote of thanks for everyone who contributed to this release.
In particular:
@Frenk - I know a few people didnāt read the breaking changes but I found the use of
"Instead of ā¦ use ā¦"
a really good way to show what and how to change. I updated my Broadlink with no problems thanks to this. Thanks!
@pnbruckner - Before this release, I had a āsimpleā time trigger based on an input_datetime:
# BEFORE
value_template: '{{ states.sensor.time.state == (states.input_datetime.coffee_start_time.attributes.timestamp | int | timestamp_custom("%H:%M", False)) }}'
# AFTER
- platform: time
at: input_datetime.coffee_start_time
SO much nicer!
It is actually even more annoying than that.
Just try typing slowly in the Telmplate Editor and watch your logsā¦
Thatās what caught my attention.
Did you try to add target?
for ex.
- service: notify.telegram_id_{{ trigger.event.data.user_id }}
message: 'Test'
target: CHANNEL_ID
I think that before you didnāt need to specify it and it used first from the list, but now you have to add it.
in the ongoing process of rewriting templates and automations triggers and conditions to replace templates, I was wondering if rewriting below condition without template
condition:
- condition: template
value_template: >
{{states('device_tracker.life360_marijn') != 'home'}}
would need to be done like:
condition:
condition: not
conditions:
- condition: state
entity_id: device_tracker.life360_marijn
state: 'home'
we cant leave out āconditions:ā can we? even if this would be the only one?
and if this set of Not conditions were to be part of the larger set of conditions, write it like this:
condition:
- condition: state
entity_id: input_boolean.espresso_notified
state: 'off'
- condition: time
after: '06:00:00'
before: '22:00:00'
- condition: not
conditions:
- condition: state
state: 'home'
though that still seems a bit more complex than
condition:
- condition: >
which if I understand it correctly is now possible tooā¦ suppose that wonāt be less efficient for the system.
