0.115: B-Day release! Media browser, tags, automations & WTH
Once inside the docker container run:
apk add cargo
cargo install py-spy
It will take a few minutes and you should end up with py-spy in /root/.cargo/bin/py-spy
Happy Birthday and thanks to each and everyone of you for your great work!
The update process was seamless and may I say faster than i was used to.
One issue so far, whenever I try to load a file from the media browser I does not work and i receive a
WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication
in the logs.
It does not matter if I try from my PC or phone, it is the same.
Any ideas?
What an amaizing job once again, thanks for your hard work HA team !
Iā€™ve just updated and noticed Gardena Smart System integration is now giving the following error :
homeassistant.setup] Unable to prepare setup for platform gardena_smart_system.sensor: Platform not found (cannot import name 'UNIT_PERCENTAGE' from 'homeassistant.const'
Happy Birthday,
Many features.
I read the breaking changes on every update and try to be prepared, well this is the 3rd clean major update I have with no warnings or broken functionally.
Kudos
I get the same error regarding UNIT_PERCENTAGE from a HACS custom integration after updating to 0.115.0:
2020-09-17 16:28:45 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform plaato.sensor: Platform not found (cannot import name 'UNIT_PERCENTAGE' from 'homeassistant.const' (/usr/src/homeassistant/homeassistant/const.py)).
Iā€™ve reinstalled the HACS custom integration, restarted HA and rebooted, but the symptom persists. @JohNan
What an awesome release! Kudos to all.
I restored to 0.144.4 and used my snapshot to restore the configuration.
I have about 30 sensors that were all broken due to this UNIT_PERCENTAGE.
Think we need to raise an issue on git.
Also the new S1c broadlink alarm integration picks up zero entities.
UNIT_PERCENTAGE was changed to PERCENTAGE in 0.115. The integration needs to update their code. Please open a github issue on the integrationā€™s repo.
I am also having very high cpu usageā€¦ didnā€™t really get a chance to look into it yet, but I am about to start investigatingā€¦
dd
data_value is in my automations.yaml ā€¦ As the logic seems to be "get rid of data_ on every variable name preceded by data_ " Iā€™m asking what goes on for data_value
Iā€™ve just installed it on my Pi, pip install py-spy seems to have worked for me :slight_smile:
same issue here after adding Kodi as integration (and removing it from yaml)
  • service: kodi.call_method
    entity_id: media_player.osmc
    method: Player.stop
    playerid: 1
does nothing, no errors
Yep same here, and my 0.114.2 install was very basic. Looking at the logfile, I have:
2020-09-17 23:10:14 ERROR (MainThread) [homeassistant.setup] Setup failed for image: Unable to import component: libopenjp2.so.7: cannot open shared object file: No such file or directory
Google seems to suggest that is something to do with Pillow, which I think I read elsewhere on here, looking for more info right nowā€¦
make sure to open an issue on github
The changes are limited to service_template and data_template.
Fixed it:
sudo apt-get install libopenjp2-7
sudo apt-get install libtiff5
Restarted HA and after a few minutes it came up.
How do we integrate the entities from the Broadlink integration? It picked up my S1c, rm pro and mini ok but the S1c shows zero entities. I would like to see the existing entities - 3 sensors and the keyfob.
For the moment I rolled back. All of these become unknown even with the new integration and old code removed.
I cant call any Kodi methods either after adding as an integration.
You have to wake up device before configuration. Support for battery powered devices is currently very limited.
I am also having extremely high cpu usageā€¦ I wasnā€™t sure if the profile.svg was possibly enough or I need to save something else also?
This first one had been running awhileā€¦
This is right after a restart of HA
Please let me know if I can provide more info
