And I can confirm that’s a NEGATIVE fix by updating to 0.117.2, as you can see in the graph attached.
It’s only been running a few hours and it seems to be on the same path to mass memory use. I’ve added the “Holt Winters” projection method, and it also shows it’s predicting a similar path to massive memory usage over time.
