I was all in with the Grid Card hoping to replace all my manual stack cards, And, it is really great if the default columns work for you. Adding columns:{#} or square:{true|false} (via the Code Editor) prevents you to returning to the Visual Editor.
Hopefully, this is just an easy Visual Editor fix.
After the update my sensor values in the frontend (which is set to English) have this format now: 512,456.78 (half a million …) : with a comma and a point for the decimal point
But I would prefer the format like this: 512456.78
Is there a way to have the frontend in English and a big number in a format like this 123456.78?
## Python 3.7 deprecated
Python 3.9 has been released on 5 October. This means that Python 3.7 support is now deprecated and will be removed after two months (which will be effective in 0.118).
This is only a concern if you are running Home Assistant Core directly on Python. You can check the Python version Home Assistant uses by going to the information screen in **Configuration** -> **Info** .
If you run Home Assistant OS, Supervised or Container, you don’t have to worry about this, as the Home Assistant project takes care of this for you. As a matter of fact, if you use one of those methods, you are already running Python 3.8.
We are currently working on ensuring Python 3.9 is fully supported and tested.
I try to log in via ssh to update hacs.
But i cannot get Terminal & SSH running.
It terminate every time, showing this in the logs:
INFO: Restoring host keys…
cp: can’t stat ‘/data/host_keys/*’: No such file or directory
My config is simple:
authorized_keys: []
password: test
server:
tcp_forwarding: false’
The payload is JSON format and previously I had to use json.loads in the appdaemon app to cast the payload from string to JSON, but now the payload is directly JSON.
Can anyone tell me if the stylesheet added with 117 has been reverted with 118, or has a workaround? Markdown works different now, which messes my entire UI. Unfortunately there is only radio silence on the github ticket I created. Lot of people who depend on markdown for their UI are kinda stuck now…
I had to skip HA 117 entirely since the change was introduced with the first version and no changes all throughout 117. I really hope there at least will be a viable workaround, so I can finally update…
My yeelight devices stopped working after upgrading to 0.118 with nothing in HA logs. Rolling back to 0.117.6 brings them back to life. Is anyone else having the same issue?
EDIT: I see https://github.com/home-assistant/core/pull/40251 related to having yeeligh in different subnets but it’s not my case.
I made the update to 0.118 last night.
After that everything went fine and I could use the two new maps Logbook and Grid.
Then I did the system update and went to bed.
This morning after getting up I look on my dashboard and notice that the new maps don’t work.
They are no longer found and do not appear in the overview.
But much worse, parts of the system do not work anymore.
No more logbook, the developer tools don’t work, I can’t view devices/entities under settings.
Everywhere the error “Error loading page” appears.
I am completely desperate …
I cannot update as I’m getting the following error:
ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-homeassistant:0.118.0 -> 500 Server Error: Internal Server Error ("toomanyrequests: You have reached your pull rate limit. You may increase the limit by authenticating and upgrading: https://www.docker.com/increase-rate-limit").
