0.26 Manually Setting State Drops Attribute
Under the latest release, 0.26, when I manually set the state of a device under the developer tools it appears to drop all attributes. I haven’t been able to manually add the Attributes back. My feeling is its might be a bug from the new Dev Tools updates.
The only reason I do this is for Locative and Device tracking. On restart it shows the devices as Away (not_home), so I manually set them to Home.
Edit: It seems that after a state change it restores the Attribute data and all automation works fine.
I’m not seeing any scrollbars on my states panel. Only the first couple of my devices are showing up though all of them are initialized and working in the views.
Also the text is a bit screwy.
EDIT: Clearing my cache manually seems to fix my problems; you may want to try this as well.
