It’s already time for 0.28 thanks to our super short release cycles. Now, it’ official…we hit 4000 stars on Github. That’s amazing. Sorry, not as amazing as all the stuff that was going on for 0.27 but still pretty awesome.
Reload automation rules
This release brings you a huge improvement of the automation and group handling. Both can be reloaded without a Home Assistant restart by calling their new reload services. The automations can be controlled directly from the frontend.
Raspberry Pi installation guide
Singleboard computers are very popular to run Home Assistant. To support this fact, the installation documentation for the Raspberry Pi devices was re-written to get users started as quickly as possible. @Landrash took the lead with on this tasks with help from @kellerza and @MartinHjelmare.
Climate and cover
There are countless bugfixes included in this release which will make your experience with the climate
and the cover
platforms better. Two week ago was the biggest merger of implementations released that ever happened in the history of Home Assistant. Thanks to @turbokongen, @pvizeli, @djbanks, @danielperna84, and others the improvements on the code and the frontend side is continuing…
API documentation
The Home Assistant API Documentation is a great addition to the already existing user documentation. The focus is not end-users but developers who want to get details about the code without actually browsing the code on Github.
Configuration validation
The validation of the configuration is still on-going. Approximately 80 % is done. This means that we will propably talk about this topic in the next release notes again. To align the configuration of components and platforms we needed to break some. Please refer to the Breaking changes section to check if you need to update your configuration or simple check your log for configuration validation errors. Thanks to @kellerza, @fabaff, @Teagan42, and @pvizeli for your effort!
All changes
Hotfix 0.28.1 - September 12
- Fix: Simplisafe alarm control panels accept any string for code (@tchellomello)
- Fix: Z-Wave would sometimes not detect all thermostats (@turbokongen)
- Fix: Automatic device tracker when 2 or more cars are tracked (@teagan42)
- Fix: Group ordering is now based on config again (@balloob, @kellerza)
Hotfix 0.28.2 - September 13
- Light - pilight: Fix send RF code (@DavidLP)
- Recorder: Fix specifying SQLite (@pvizeli)
- Wink: Fix garage door detection (@turbokongen)
- Climate - Ecobee: Fix inverted high and low temperatures (@turbokongen)
- Allow changing covers using scenes (@nvella)
- Device tracker - Automatic: Fix polling (@teagan42)
Breaking changes
OpenweatherMap entity IDs are now like
sensor.owm_temperature
. Previously they were likesensor.weather_temperature
. Apologies for this change, but we needed to make OpenWeatherMap more generic now that we have many weather platforms. - Updates of configuration variables due to configuration check or alignment with other platforms. Please update your configuration entries according to the documentation:
- Custom components extending
BaseNotificationService
need to be aware thatkwargs.get(ATTR_TITLE)
will now returnNone
if a title has not been set, and will need to specifykwargs.get(ATTR_TITLE, ATTR_TITLE_DEFAULT)
if they always require a title.
If you need help…
…don’t hesitate to use our Forum or join us for a little chat.
This is a companion discussion topic for the original entry at https://home-assistant.io/blog/2016/09/10/notify-group-reload-api-pihole/
