I upgraded to 0.36 last night, and as soon as I did I’ve been noticing major performance issues – motion/light triggers take upwards of 10+ seconds to activate, when manually triggering a scene it takes up to 20 seconds for all the lights to turn on (and they “trickle” on one by one), or they just never trigger at all.
My setup mostly consists of MQTT “lights” which are actually z-wave switches proxied through a SmartThings hub. Trigger the lights from SmartThings results in instantaneous response. Watching MQTT messages on my network through MQTTlens definitely suggests the lag is happening in Home Assistant.
Checking home-assistant.log (I’m on a Raspberry Pi 3 with the AIO installer), I see this:
OSError: [Errno 24] Too many open files
17-01-16 15:15:40 homeassistant.core: Error doing job: socket.accept() out of system resource
File "/usr/lib/python3.4/asyncio/selector_events.py", line 137, in _accept_connection
conn, addr = sock.accept()
File "/usr/lib/python3.4/socket.py", line 184, in accept
fd, addr = self._accept()
17-01-16 15:15:41 homeassistant.core: Error doing job: socket.accept() out of system resource
17-01-16 15:15:42 homeassistant.core: Error doing job: socket.accept() out of system resource
17-01-16 15:15:43 homeassistant.core: Error doing job: socket.accept() out of system resource
17-01-16 15:15:44 homeassistant.core: Error doing job: socket.accept() out of system resource
17-01-16 15:15:45 homeassistant.core: Error doing job: socket.accept() out of system resource
17-01-16 15:15:46 homeassistant.core: Error doing job: socket.accept() out of system resource
top
shows the hass
and homebridge
processes consistently eating most of the CPU cycles:
13754 hass 20 0 201656 60044 8260 S 40.4 6.3 1:55.12 hass
31506 hass 20 0 169604 47772 7976 S 23.2 5.0 119:47.59 homebridge
132 root 20 0 10296 4280 3940 S 22.2 0.5 125:55.62 systemd-journal
458 root 20 0 32144 2608 848 S 6.0 0.3 36:58.88 rsyslogd
19 root 20 0 0 0 0 S 0.3 0.0 0:33.62 ksoftirqd/3
475 mosquit+ 20 0 5564 1844 1520 S 0.3 0.2 22:03.35 mosquitto
13820 pi 20 0 5304 2520 2020 R 0.3 0.3 0:00.15 top
1 root 20 0 22864 2488 1600 S 0.0 0.3 1:12.93 systemd
Not sure what to do at this point. Any suggestions?
