hagensieker
(John Hagensieker)
1
I upgraded and have this. The whole command is a single line and way too long to copy. Here’s the first grab.
17-02-26 23:47:34 ERROR (MainThread) [homeassistant.bootstrap] Invalid config for [homeassistant]: expected a dictionary for dictionary value @ data[‘customize’]. Got [OrderedDict([(‘entity_id’, 'switch etc etc etc etc etc
hagensieker
(John Hagensieker)
2
This is the top of my configuration.yaml
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: xxxxxx
longitude: -xxxxx
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 6
# metric for Metric, imperial for Imperial
unit_system: imperial
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/New_York
customize:
- entity_id: switch.arest_pin_two
assumed_state: false
- entity_id: switch.arest_pin_zero
- entity_id: switch.front_window_outlet
entity_picture: /local/ecoplug.jpg
- entity_id: switch.hall_outlet
- entity_id: switch.living_room_outlet
- entity_id: switch.den_outlet
- entity_id: light.master_bedroom_lamp
entity_picture: /local/lifx_logo.png
- entity_id: light.living_room_lamp
- entity_id: switch.ge_12722_onoff_relay_switch_switch_5_0
entity_picture: /local/ge.png
friendly_name: Front Porch Light
entity_picture: /local/relay.jpg
- entity_id: switch.das_relay
entity_picture: /local/relay2.jpg
- entity_id: switch.ge_12722_onoff_relay_switch_switch_2_0
friendly_name: Recessed Kitchen
- entity_id: switch.ge_12722_onoff_relay_switch_switch_3_0
friendly_name: Outdoor Light Garage
- entity_id: light.ge_12724_3way_dimmer_switch_level_4_0
friendly_name: Recessed Dimmer Den
Sam
3
Post the complete error message after running “hass --script check_config”
hagensieker
(John Hagensieker)
4
(homeassistant_venv) homeassistant@homeassistant:~/.homeassistant$ hass --script check_config
INFO:homeassistant.util.package:Attempting install of colorlog>2.1,<3
Testing configuration at /home/homeassistant/.homeassistant
17-02-27 00:23:57 ERROR (MainThread) [homeassistant.bootstrap] Invalid config for [homeassistant]: expected a dictionary for dictionary value @ data[‘customize’]. Got [OrderedDict([(‘entity_id’, ‘switch.arest_pin_two’), (‘assumed_state’, False)]), OrderedDict([(‘entity_id’, ‘switch.arest_pin_zero’), (‘assumed_state’, False)]), OrderedDict([(‘entity_id’, ‘switch.front_window_outlet’), (‘entity_picture’, ‘/local/ecoplug.jpg’)]), OrderedDict([(‘entity_id’, ‘switch.hall_outlet’), (‘entity_picture’, ‘/local/ecoplug.jpg’)]), OrderedDict([(‘entity_id’, ‘switch.living_room_outlet’), (‘entity_picture’, ‘/local/ecoplug.jpg’)]), OrderedDict([(‘entity_id’, 'switch.den… (See /home/homeassistant/.homeassistant/configuration.yaml, line 2).
Failed config
homeassistant:
customize: [source /home/homeassistant/.homeassistant/configuration.yaml:14]
- assumed_state: False
- entity_id: switch.front_room_light
entity_picture: /local/wemo.png
- entity_id: light.ge_unknown_type4c42_id3031_level_6_0
friendly_name: Garage Light
elevation: 6
latitude:
longitude: -
Successful config (partial)
homeassistant:
Sam
5
Was this working before ?
There are a couple of different formats you can use - see the install guide https://home-assistant.io/docs/configuration/customizing-devices/ for an example of the other format.
The other format would look something like
customize:
switch.arest_pin_two:
switch.arest_pin_zero:
hagensieker
(John Hagensieker)
6
Yes working perfect with 0.38.4 Just when I upgrade to 0.39.0 Reinstalling to 0.38.4 makes it work again.
Sam
7
Apologies - didn’t quote my reply properly. Do you want to try the other format or have you already gone back to 0.38.4 ?
andrewpc
(Andrew)
8
The release notes for 0.39 detail the breaking change for customize.
A tool is provided here to convert your format:
https://jsfiddle.net/balloob/d2e56q6f/1/
This worked for me.
hagensieker
(John Hagensieker)
9
I’ve no choice but to go back right now. playing around with the tool andrewpc posted. Not having any luck so far.
hagensieker
(John Hagensieker)
10
I actually got the customize to kinda sorta work but now zwave config is broken. Back to 0.38.4 and going to bed . Fight another day ![:grin: :grin:](https://community.home-assistant.io/images/emoji/twitter/grin.png?v=9)
hagensieker
(John Hagensieker)
11
I got it. Ran the whole configuration.yaml in the tool and only had to change under zwave:
customize: to device_config:
All is working. One tiny problem but I’ll start another thread.
turboc
(Chip Cox)
12
Ok,
Just pretend I don’t know anything. (not a far stretch) how do I use this tool? I see html and java script…
I pasted in the records from my config file. They showed up over in input like I guess they should. I click convert and nothing happens.
