WE HAVE THEMES 🎨👩🎨
Our already amazing frontend just got even more amazing thanks to @andrey-git. With the new theme support you can be in control of the primary color, accent color and a whole bunch more.
You can specify themes using new configuration options under frontend.
frontend:
themes:
green:
primary-color: "#6CA518"
Once a theme is defined, use the new frontend service frontend.set_theme
to activate it. More information in the docs.
Screenshot of a green dashboard
Not all parts of the user interface are themable yet. Expect improvements in future releases.
Kiosk mode
Another great new improvement for the frontend is the addition of a kiosk mode. When the frontend is viewed in kiosk mode, the tab bar will be hidden.
To activate kiosk mode, navigate to https://hass.example.com:8123/kiosk/group.living_room_view
. Note that for default_view
the url is just https://hass.example.com:8123/kiosk
This feature has also been brought to you by @Andrey-git! Big shout out to him for his continuous efforts to bring Home Assistant to the next level.
New Platforms
- Add london_underground (@robmarkcole - #8272) (sensor.london_underground docs) (new-platform)
- Add citybikes platform (@aronsky - #8202) (sensor.citybikes docs) (new-platform)
- Add One-Time Password sensor (OTP) (@postlund - #8332) (sensor.otp docs) (new-platform)
- Add component for xiaomi robot vacuum (switch.xiaomi_vacuum) (@rytilahti - #7913) (switch.xiaomi_vacuum docs) (new-platform)
- LaMetric platform and notify module (@open-homeautomation - #8230) (lametric docs) (notify.lametric docs) (new-platform)
- New component to connect to VELUX KLF 200 Interface (@Julius2342 - #8203) (velux docs) (scene.velux docs) (new-platform)
- New service
send_magic_packet
with new componentwake_on_lan
(@azogue - #8397) (wake_on_lan docs) (new-platform) - Add support for Prometheus (@rcloran - #8211) (prometheus docs) (new-platform)
- Refactored Amcrest to use central hub component (@tchellomello - #8184) (amcrest docs) (camera.amcrest docs) (sensor.amcrest docs) (breaking change) (new-platform)
- Added media_extractor service (@minchik - #8369) (media_extractor docs) (new-platform)
- Vizio SmartCast support (@vkorn - #8260) (media_player.vizio docs) (new-platform)
Release 0.49.1 - July 24
- Fix TP-Link device tracker regression since 0.49 (@maikelwever - #8497) (device_tracker.tplink docs)
- prometheus: Convert fahrenheit to celsius (@rcloran - #8511) (prometheus docs)
- Update dlib_face_detect.py (@pvizeli - #8516) (image_processing.dlib_face_detect docs)
- Realfix for dlib (@pvizeli - #8517) (image_processing.dlib_face_detect docs)
- Attach the
chat_id
for a callback query from a chat group (fixes #8461) (@azogue - #8523) (telegram_bot docs) - Fix support for multiple Apple TVs (@postlund - #8539)
- LIFX: assume default features for unknown products (@amelchio - #8553) (light.lifx docs)
- Fix broken status update for lighting4 devices (@ypollart - #8543) (rfxtrx docs) (binary_sensor.rfxtrx docs)
- zha: Update to bellows 0.3.4 (@rcloran - #8594) (zha docs)
- Fix STATION_SCHEMA validation on longitude (@clkao - #8610) (sensor.citybikes docs)
- Bumped Amcrest version (@tchellomello - #8624) (amcrest docs)
- Check if /dev/input/by-id exists (@schaal - #8601) (keyboard_remote docs)
- Tado Fix #8606 (@filcole - #8621) (climate.tado docs)
- prometheus: Fix zwave battery level (@rcloran - #8615) (prometheus docs)
- ubus: Make multiple instances work again (@glance- - #8571) (device_tracker.ubus docs)
- Properly slugify switch.flux update service name (@jawilson - #8545) (switch.flux docs)
If you need help…
…don’t hesitate to use our very active forums or join us for a little chat. The release notes have comments enabled but it’s preferred if you use the former communication channels. Thanks.
Reporting Issues
Experiencing issues introduced by this release? Please report them in our issue tracker. Make sure to fill in all fields of the issue template.
Breaking Changes
- UPC Connect component no longer needs a password passed into the configuration. (@Flavien - #8335) (device_tracker.upc_connect docs) (breaking change)
- The Apple TV platform has been upgraded to a component and a remote platform has been added. This requires your Apple TV configuration to be moved to the new
apple_tv
component. (@postlund - #8122) (media_player.apple_tv docs) (breaking change)
apple_tv:
- name: Apple TV
host: 10.0.10.20
login_id: 00000000-1234-5678-9012-345678901234
start_off: true
credentials: 8660DEA5154FB46B:20B94847926112B3F46F85DB3A7311830463BF65570C22C3786E27F38C3326CF
- Refactored Amcrest to use central hub component to prepare for future integrations. This requires your Amcrest configuration to be moved to the new
amcrest
component. (@tchellomello - #8184) (amcrest docs) (camera.amcrest docs) (sensor.amcrest docs) (breaking change) (new-platform)
amcrest:
- host: !secret amcrest_living
username: !secret amcrest_living_username
password: !secret amcrest_living_password
resolution: low
stream_source: snapshot
sensors:
- motion_detector
- ptz_preset
All changes
- Version bump to 0.49.0.dev0 (@fabaff - #8266)
- Upgrade pyowm to 2.7.1 (@fabaff - #8274) (sensor.openweathermap docs) (weather.openweathermap docs)
- Don’t call update() in constructor (@fabaff - #8276) (sensor.openweathermap docs)
- Update apcaccess to 0.0.13. Add “Percent Load Capacity” to INFERRED_UNITS. (@michaelarnauts - #8277) (apcupsd docs) (sensor.apcupsd docs)
- Update knxip to 0.4 (better handling of reconnects) (@open-homeautomation - #8289) (knx docs)
- pytado moved to pypi (@wmalgadey - #8298) (tado docs) (climate.tado docs)
- Fix doc link in header (@robmarkcole - #8305) (sensor.london_underground docs)
- Upgrade discord.py to 0.16.8 (@fabaff - #8304) (notify.discord docs)
- zha: Strip whitespace from device names (@rcloran - #8306) (zha docs)
- Upgrade chardet to 3.0.4 (@fabaff - #8313)
- Upgrade aiohttp to 2.2.2 (@fabaff - #8314)
- Fix pylint issue (@fabaff - #8325) (snips docs)
- vsure 1.3.7 (@persandstrom - #8321) (verisure docs)
- Update pyEmby to fix media images (@mezz64 - #8331) (media_player.emby docs)
- Partially revert #7931 (@fabaff - #8326) (sensor.yweather docs)
- Only allow ‘tls_insecure_set()’ if cert is present (fixes #8329) (@fabaff - #8337) (mqtt docs)
- Fix issue #8285 (@Sabesto - #8340) (modbus docs) (binary_sensor.modbus docs) (climate.flexit docs) (sensor.modbus docs) (switch.modbus docs)
- Bump dlib face_recognition to 0.2.0 (@pvizeli - #8345) (image_processing.dlib_face_detect docs) (image_processing.dlib_face_identify docs)
- Update Avion and Decora switches to match upstream changes (@mjg59 - #7903) (light.avion docs) (light.decora docs)
- Fix the “302” error in the UPC Connect component and remove the need to specify the router password (@Flavien - #8335) (device_tracker.upc_connect docs) (breaking change)
- Add new feature to Apple TV platform (@postlund - #8122) (media_player.apple_tv docs) (breaking change)
- Fix some issues for PyLint 1.7.2 (@balloob - #8356)
- Fix pylint 1.7.2 no-else-return issues (@balloob - #8361)
- Upgrade aiohttp to 2.2.3 (@fabaff - #8363)
- Remove some more usage of run_in_executor (@balloob - #8352)
- Correct spelling of aliases, deprecate old config options. (@aequitas - #8348) (rflink docs) (light.rflink docs) (sensor.rflink docs) (switch.rflink docs)
- Allow Pilight Binary Sensor to control reset_delay_sec through configuration (@clarkewd - #8358) (binary_sensor.pilight docs)
- Mqtt client_id fix for #8315 (@heinemml - #8366) (mqtt docs)
- Allow all panel urls (@balloob - #8368)
- Update pyHik to catch XML errors (@mezz64 - #8384) (binary_sensor.hikvision docs)
- update version (@wardcraigj - #8380) (alarm_control_panel.totalconnect docs)
- buienradar==0.7, fix winddirection/azimuth, logging (@mjj4791 - #8281) (sensor.buienradar docs) (weather.buienradar docs)
- Try catch around database updates in recorder. Resolves 6919 (@mitchese - #8349) (recorder docs)
- Fix Amazon Polly with non english voices. #8377 (@CharlesBlonde - #8378) (tts.amazon_polly docs)
- Fix TTS options. #8375 (@CharlesBlonde - #8376) (tts docs)
- Add address-specific KNX listeners that fire events on the HASS bus (@open-homeautomation - #8374) (knx docs)
- GTFS: check start/end date on services (@Kernald - #8373) (sensor.gtfs docs)
- Implement KNX dimming functionality (@open-homeautomation - #8371) (light.knx docs)
- Add Soundtouch support for playing an HTTP url (@CharlesBlonde - #8370) (media_player.soundtouch docs)
- Modbus fixes to work with pymodbus 1.3.1 (@Sabesto - #8365) (modbus docs) (binary_sensor.modbus docs) (sensor.modbus docs) (switch.modbus docs)
- Cleanup the asuswrt component (@mattsch - #8359) (device_tracker.asuswrt docs)
- cover_template:i open/close/stop actions no longer required. Improve tests (@PhracturedBlue - #8344) (cover.template docs)
- Prevent errors on Octoprint sensors and binary_sensors when Octoprint and/or Printer are off (@w1ll1am23 - #8343) (octoprint docs) (binary_sensor.octoprint docs) (sensor.octoprint docs)
- Presence detection for tp link eap225 (@alexrockt - #8322) (device_tracker.tplink docs)
- zha light: Refresh at startup (@rcloran - #8310) (light.zha docs)
- zha: Try multiple reads to get manufacturer/model (@rcloran - #8308) (zha docs)
- Upnp mapping notification (@dgomes - #8303) (upnp docs)
- Use user-set device names for Linksys Smart Wi-Fi routers (3) (@Klikini - #8300) (device_tracker.linksys_smart docs)
- Added support for upload of remote or local files to slack (@simaosimao - #8278) (notify.slack docs)
- Update avion.py (@pvizeli - #8364) (light.avion docs)
- Sets spotify media_type to music (@Tommatheussen - #8387) (media_player.spotify docs)
- Update waqi sensor (@andrey-git - #8385) (sensor.waqi docs)
- Update aiolifx (@amelchio - #8396) (light.lifx docs)
- Code owners (@balloob - #8393)
- Add new Dyson sensors (@CharlesBlonde - #8199) (dyson docs) (fan.dyson docs) (sensor.dyson docs)
- Fix CODEOWNERS z-wave team name (@armills - #8400)
- Upgrade Sphinx to 1.6.3 (@fabaff - #8405)
- Use upstream RachioPy, fix manual run switches (@Klikini - #8286) (switch.rachio docs)
- Marrantz SR5006 & SR5006 treated as AVR-X device Fixed Mapping of Media Player and AUX input functions (@scarface-4711 - #8409) (media_player.denonavr docs)
- Properly handle the case when a group includes itself. (@andrey-git - #8398) (group docs)
- Add set_operation_mode support to generic_thermostat (@mtreinish - #8392) (climate.generic_thermostat docs)
- Make gzips reproducible by excluding timestamp (@armills - #8420)
- Do not overwrite a custom hyperion light name with the hostname of the server. (@doctorjames - #8391) (light.hyperion docs)
- Fixed link to documentation (@Julius2342 - #8424) (velux docs) (scene.velux docs)
- Fix KeyError (fixes #3721, fixes #7241) (@fabaff - #8428) (sensor.uber docs)
- Use HA lat/long for the start (fixes #3971) (@fabaff - #8429) (sensor.uber docs)
- bump python-mirobo requirement to support newer firmwares and more (@rytilahti - #8431) (switch.xiaomi_vacuum docs)
- New service
send_magic_packet
(@azogue - #8397) (wake_on_lan docs) (new-platform) - Integrate utility functions into restricted Python environment (@open-homeautomation - #8427) (python_script docs)
- Allow Twitter notifications to include media (@MikeChristianson - #8282) (notify docs) (notify.twitter docs)
- Fix typo (sending USERNAME instead of PASSWORD) introduced in #7963 (@thecynic - #8433) (lutron docs)
- zha: Handle both input and output clusters (@rcloran - #8410) (zha docs) (binary_sensor.zha docs) (light.zha docs) (sensor.zha docs)
- Fix radiothermostat -1 value issue (@aneisch - #8395) (climate.radiotherm docs)
- Updated pyvera (@alanfischer - #8437) (vera docs)
- Upgrade phue to 1.0 (fixes #7749) (@fabaff - #8444) (light.hue docs)
- Add effects (@fabaff - #8442) (light.mystrom docs)
- Exclude ‘TAXI’ product (fixes #8401) (@fabaff - #8438) (sensor.uber docs)
- Switch pyW215 to pypi (@andrey-git - #8445) (switch.dlink docs)
- DHT support for humidity and temperature offset (@gitmopp - #8238) (sensor.dht docs)
- Add support for rain and moisture sensors (@sdague - #8440) (sensor.arwn docs)
- Hass.io: Disable timeout when updating OS/supervisor/hass (@balloob - #8447) (hassio docs)
- Fix Arlo Q not working with 0.48.1 (@viswa-swami - #8446) (camera.arlo docs)
- Support for Plex servers with enforced SSL (@nmaggioni - #8341) (media_player.plex docs)
- Upgrade youtube_dl to 2017.7.9 (@fabaff - #8450) (media_extractor docs)
- Implement a bridge between HASS event bus and KNX bus to send events (@open-homeautomation - #8449) (knx docs)
- LIFX: improve light availability (@amelchio - #8451) (light.lifx docs)
- LIFX: make broadcast address configurable (@amelchio - #8453) (light.lifx docs)
- Backend support for themes (@andrey-git - #8419)
- upgrade broadlink (@danielhiversen - #8462) (sensor.broadlink docs) (switch.broadlink docs)
- upgrade rfxtrx lib (@danielhiversen - #8463) (rfxtrx docs)
- Plex: Add exception handler when connection fails (@abmantis - #8179) (media_player.plex docs)
- HomeMatic dependency upgrade + IP Wall Thermostat support (@danielperna84 - #8465) (homematic docs)
- Add kiosk-mode panel (@andrey-git - #8457)
This is a companion discussion topic for the original entry at https://home-assistant.io/blog/2017/07/15/release-49/
