With out any zigbee devices paired I can restart server and zha starts without issues.
However if I have a zigbee device paired zha will fail to start when trying to read the zigbee.db.
I believe when I add a device there is something bad written to the db.
The fix is to delete the zigbee.db and then zha will start ok.
I have tried Smartthings Open/Closed sensor and Smartthings Motion sensor with same result.
The error is:
2017-07-20 06:56:44 INFO (MainThread) [homeassistant.setup] Setting up zha
2017-07-20 06:56:44 DEBUG (MainThread) [bellows.zigbee.appdb] Loading application state from /config/zigbee.db
2017-07-20 06:56:44 ERROR (MainThread) [homeassistant.setup] Error during setup of component zha
File "/usr/src/app/homeassistant/setup.py", line 191, in _async_setup_component
result = yield from component.async_setup(hass, processed_config)
File "/usr/src/app/homeassistant/components/zha/__init__.py", line 87, in async_setup
APPLICATION_CONTROLLER = ControllerApplication(ezsp_, database)
File "/usr/local/lib/python3.6/site-packages/bellows/zigbee/application.py", line 30, in __init__
self._dblistener.load()
File "/usr/local/lib/python3.6/site-packages/bellows/zigbee/appdb.py", line 204, in load
clus = ep.in_clusters[cluster]
KeyError: 0
@rcloran I saw there were some changes related to clusters being changed to in_clusters/out_clusters.
Any chance this db error is related?
I tried 0.49 and dev (7/20) version of HA docker images.
I tried copying over just the init and then the entire bellows dir from 9c9856bccf2fb04adddb0a0f49fc5c3185f1ded3.zip
on 0.49
However, I must be doing something wrong as I get below error.
Can you help with detailed instructions?
2017-07-21 03:39:48 ERROR (MainThread) [homeassistant.setup] Error during setup of component zha
File "/usr/src/app/homeassistant/setup.py", line 187, in _async_setup_component
File "/usr/src/app/homeassistant/components/zha/__init__.py", line 79, in async_setup
import bellows.ezsp
File "/usr/local/lib/python3.6/site-packages/bellows/__init__.py", line 295, in <module>
from . import clusters # noqa: F401, F402
ImportError: cannot import name 'clusters'
