I updated to 0.54.0 and all my sensors connected to my Vera Edge now show “Unknown”. The sensors are working on the Vera. I don’t get any error message in the log.
Other devices like switches that is connected to the Vera is shown properly and can be controlled through HASS as usual.
I have tried removing the line for Vera in configuration.yaml, restrating and then adding it back. This did not change anything.
No, that didn’t work with HASS installed using the All-In-One-Installer. I get some error:
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/basecommand.py", line 215, in main
status = self.run(options, args)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/commands/install.py", line 289, in run
delete=build_delete) as build_dir:
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/utils/build.py", line 22, in __init__
name = os.path.realpath(tempfile.mkdtemp(prefix="pip-build-"))
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/tempfile.py", line 426, in mkdtemp
dir = gettempdir()
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/tempfile.py", line 370, in gettempdir
tempdir = _get_default_tempdir()
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/tempfile.py", line 312, in _get_default_tempdir
dirlist)
FileNotFoundError: [Errno 2] No usable temporary directory found in ['/tmp', '/var/tmp', '/usr/tmp', '/home/pi']
I assume this error with Vera will be fixed in the next stable version so I’ll just wait.
I tried to search for vera.py on my Rpi3 using WinSCP but couldn’t find anything, so I can’t update the file. I assume it’s because I use the AIO version of HASS.
I love HASS but it’s frustrating when new versions breaks functionality that previously worked properly.
