![](upload://smANY5qLNrqrfiyt7KeA5ysniIe.png)
Beside the improved Wink support which was contributed by @w1ll1am23, ships this release a wide variety of new components and platforms. The input_slider
components has received a makeover by @BioSehnsucht and is now input_number
. @tinloaf added a feature that allows you to enter dates: input_datetime
. Both will help you to improve your automation rules.
DuckDNS
Using Home Assistant with DuckDNS for Dynamic DNS (DDNS or DynDNS) is an old story. DuckDNS is also integrated in Hass.io. 0.55 ships a component for non Hass.io users to get a similar feature.
Recorder
The purging of data was improved. With purge_interval
you can schedule regular purges of older events and states. In combination you can specify with purge_keep_days
the amount of days you want to keep. The new service recorder.purge
allows you to handle this task when needed.
Owntracks
Owntracks is an easy way to track your devices. For some times we have the device tracker which depends on MQTT but thanks to a new feature in Owntracks we can now offer support for HTTP. The new platform doesn’t require a MQTT broker but sends messages directly as HTTP requests to Home Assistant.
Tibber
This release introduces a new sensor: Tibber. The sensor provides the current electricity price if you are a Tibber customer. This will allow you to make automation for turning off the heater when the electricity price is high or only charge your electric car when the prices are low. We further plan to add support for showing future electricity prices and historic electricity consumption data. Tibber is currently only available in Norway and Sweden
The Things Network
The Things Network (TTN) is a LoRaWAN based network especially designed for IoT devices. With this integration one can observe the state of devices which are out of range of the local WiFi network as long as they are connected to a TTN gateway.
New Platforms
0.55.1 - October 15
If you need help…
…don’t hesitate to use our very active forums or join us for a little chat. The release notes have comments enabled but it’s preferred if you use the former communication channels. Thanks.
Reporting Issues
Experiencing issues introduced by this release? Please report them in our issue tracker. Make sure to fill in all fields of the issue template.
Breaking Changes
All changes
This is a companion discussion topic for the original entry at https://home-assistant.io/blog/2017/10/07/release-55/
