Updated to the latest version of HA this morning and since then it has broken my input_sliders.
2017-11-04 11:02:07 ERROR (MainThread) [homeassistant.loader] Unable to find component input_slider
2017-11-04 11:02:07 ERROR (MainThread) [homeassistant.setup] Setup failed for input_slider: Component not found.
I had a look through the notes and maybe I missed it but I couldn’t see any thing relating to input_sliders being changed so not sure why they are now broken…
Technically you wouldn’t need to rename the input_slider.yaml since that is just a reference to the file. But it would make sense if your input_numbers reside in a file with the same name.
All the other occurances of input_slider have to be renamed, as you have figured out meanwhile.
Yeah I thought as much, I wasn’t sure if the file name not being changed would break anything but seems not. For consistency I have changed the file name too so it makes sense. Ill only come to want to change something in a couple months time and wonder why I cant find something because I didn’t change the file name and get confused!
