Is that due to 58.1 or forcing update.
I think forcing the update on Hass.io, because when I install a clean Home Assistant 58.1 (not Hass.io) everything works fine.
Also now, my Hass.io frontend isn’t working anymore, the page keeps loading and there are no errors when I run the “hassio homeassistant logs” command.
58.1 is officially live
Update through hassio and the harmony update is amazing there is hardly any lag now
Thank you devs
Yep - I wasn’t seeing the update through Hass.io but via SSH I could do a hassio homeassistant update and it installed. Now to play with the Google Assistant enhancement.
As suspected we skipped 0.58 and went straight to 0.58.1 Thanks Devs.
