Why did I click that update button? Not much works after the update to 0.60. Wink is not discovered, a 4 Ch Sonoff running Tasmota using emulated Hur only shows one channel, groups are messed up… How can I get back to 59.2?
edit… it seems the 0.60 install was corrupt. Starting over and getting things back.
edit… spent some time putting things back together and have a strange problem left over. I have Hue and emulated hue devices connected and hassio now confuses them. After a power-up everything seems fine and I can see and control all devices but get the configure hue dialog on the web page. When I click it and then press the button on the hue it goes away but then an emulated hue device that was working fine assumes the identity of a real hue device. It even substitutes itself in a group that included the emulated device.
Can’t help with these problems but I do have my own problms after updateing.
HASSIO front end is realy slow, history is dead, and I get a bunch of weird errors after the update while before all was running as it should. Her the errors…
Error doing job: Fatal error on transport TCPTransport (error status in uv_stream_t.read callback)
03:20 /usr/lib/python3.6/site-packages/homeassistant/core.py (ERROR)
Unable to find service input_number/select_value
03:04 core.py (WARNING)
Unable to find service sensor/turn_off
22:51 core.py (WARNING)
Unable to find service input_number/turn_off
Check your available SD card space (ie: make sure the DB2 file hasn’t gotten massive and chewed up all your space). I had my HassIO going crazy last week and couldn’t understand why. It wasn’t until after I had unfortunately tried to go back in time with a snapshot that I discovered the DB2 file was about 4GB and I had no room left for HassIO to run.
It would be so much better if HassIO would give a warning that space is low rather than just suddenly acting strange and having certain functions not work. I have since implemented a DB restriction to only keep 2 weeks worth of data which should prevent it happening again.
It might be worth mentioning also, that SD cards have a pretty limited lifespan and will slowly begin to corrupt once a certain amount of data has been written to it
Thanks for the info. I did start over fresh so the db2 size is still small. I;ll replace the SD card once the stores open again. I have managed to get almost everything working again, but still have odd device issues where they swap places, randomly don’t show in history, group tabs or <> but are still controlled properly from automations.
I am also getting strange things going on with 0.6. I can’t get my config file to checkout and I haven’t edited it since the last known good version that worked previously. The returned config test output is below. The last line is something about light.True. I also see the error in my main hass.io Log
Unable to find component light.True
11:22 PM loader.py (ERROR)
Everything mostly seems to load but not sure what is going on with this.
Testing configuration at /config
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setting up http
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setting up recorder
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds.
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.0 seconds.
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setting up api
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setting up system_log
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setting up history
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds.
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setting up frontend
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setting up sun
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setting up map
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setting up group
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setting up sensor
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setting up updater
2017-12-25 23:25:55 ERROR (MainThread) [homeassistant.loader] Unable to find component light.True
2017-12-25 23:25:55 INFO (MainThread) [homeassistant.setup] Setting up emulated_hue
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.2 seconds.
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.2 seconds.
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.2 seconds.
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.2 seconds.
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.2 seconds.
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setup of domain emulated_hue took 0.0 seconds.
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setting up config
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setting up logbook
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setting up hassio
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setting up tts
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.0 seconds.
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setting up automation
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setting up switch
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setting up light
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setting up script
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setting up fan
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 0.0 seconds.
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.0 seconds.
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 0.0 seconds.
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setup of domain light took 0.0 seconds.
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2017-12-25 23:25:56 INFO (MainThread) [homeassistant.setup] Setup of domain fan took 0.0 seconds.
Failed config
General Errors:
- Platform not found: light.True
I think what is going on with my configuration is that I have a real Hue Bridge and a Sonoff 4CH Pro acting like a Hue bridge and Hassio is confusing the devices from both as if they are from one bridge. In my config folder I have two phue-xxx.conf files with the IPs of the two devices (hue hub and Sonoff). Nothing to be done there though. I think I may have to move the Sonoff over to MQTT to avoid interfering with the Hue. My current config worked up to v0.60.
I’m running Hass.io and am unsure how to check my SD card space. I think I found something a while back but can’t remember how. Any tips for this kind of docker setup (seems like VMs they each had defined space when I found it once before)? Also, for checking card health?
Same but I’m only keeping a day. Hassio still locks up pretty much every day and needs a reboot. I’m using the noobs card I got from RS when I got the Pi3. Maybe I need to switch to a Samsung EVO. (It’s a 32gb card)
If you do, hopefully you have better success than me. I found that my Pi didn’t like high capacity cards and I ended up with an 8Gb old one that was lying around. The problem with the larger cards (brand new) became evident when HassIO wouldn’t even load after initial install. I tried out the old 8Gb and everything installed and booted up perfectly…
my larger card wasn’t the NOOBS one this time around. I think the 8Gb I ended up with was originally a NOOBS that I formatted after it had OSMC previously…
