I have different tabs for different rooms on my front end configuration. Each one has lights and other components for each room. Nothing crazy. Then I have an ‘All Lights’ tab that lets me see every connected light I have. Since installing 0.61.1, my All Lights tab doesn’t show all my lights, yet the same lights show up in the other room tabs. It seems to be limited to GE and Homeseer Z wave switches for some reason. LIFX, Yeelight, and some Z wave dimmers show up. I have verified the entity IDs are exactly the same as in the groups that work and there are no logs to show any errors.
As an example, as part of my Outside tab, I call this group and all these lights show up just fine:
outside_lights:
view: no
entities:
- switch.d31_porch_lights_switch
- switch.d22_deck_lights_switch
- switch.d8_security_lights_primary_switch
My All Lights tab looks like this:
all_lights:
view: yes
icon: mdi:lightbulb
entities:
- group.light_switches
light_switches:
view: no
entities:
- light.upstairs_lamp
- light.master_bedroom_lamp
- switch.d24_garage_lights_switch
- light.downstairs_lamp
- light.d3_dimmer_level #MB Rock Lamp
- light.yeelight_strip_zzzzzzzz #Bed Lights
- light.yeelight_strip_xxxxxxxx #Fireplace Light
In this group, the porch lights, deck lights, security lights, and garage lights do not show up at all.
As a test, I removed the subgroup and put all the light and switch entity IDs directly into the all lights group and reloaded Groups. I ended up with two subgroups: switches and lights. Everything showed up, just segregated by entity type.
Has anyone else seen this behavior?
EDIT: Something else I realized, with the normal configuration, even though I have switches mixed in, the group actually shows up with the name “Light” as if it just filtered out lights and disregarded my group name altogether.
EDIT 2: In moving entities back and forth between group and subgroup, and going back to the original configuration, the tab loads correctly when I reload groups. If I restart Hass though, it reverts back to ignoring switches.
