0.62.1 broke Samsung tv
0.62.1 broke my samsung tv remote.
Hassio do not recognize my Samung tv any more.
I can turn on the tv but not Off, and the status is always off
Same here, I can see it in the UI but can’t do anything with it…
Has anyone reported it as an issue yet?
Same thing happens here.
Please open an issue and reference two recent PRs:
https://github.com/home-assistant/home-assistant/pull/11998
https://github.com/home-assistant/home-assistant/pull/10907
Seems to be an issue of not having enough testers on different TVs so please follow that pr and offer to help if you can!
As far as I could read, this PR 11998 is already supposed to fix this issue with Samsung TVs. I’ll test it later and let you know.
PR 11998 manually applied in my HAssbian did the trick for me :wink:
I have set a timeout to 3, and that helpt me :smiley:
I had opened a merge request to solve those issue with samsung TV:
But it was refused arguing that the function should be integrated in the upstream samsungctl library…
