I’m having the same issue with all of the default groups disappearing. Additionally, it seems my automations no longer trigger, when they previously worked flawlessly.
EDIT: user error, everything seems to work for Harmony in 0.62.1
What time can fit on ASUS TinkerBoard GPIO?hoped…
I am also having trouble with automations triggering.
Xiaomy wifi issues seemed to be resolved, but in 0.62.1 they are still broken:
2018-02-01 13:22:14 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform xiaomi_miio
File “/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py”, line 189, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File “/usr/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 245, in result
raise self._exception
File “/usr/lib/python3.6/asyncio/tasks.py”, line 180, in _step
result = coro.send(None)
File “/usr/lib/python3.6/asyncio/coroutines.py”, line 210, in coro
res = func(*args, **kw)
File “/usr/lib/python3.6/site-packages/homeassistant/components/switch/xiaomi_miio.py”, line 41, in async_setup_platform
from miio import Device, DeviceException
File “/usr/lib/python3.6/site-packages/miio/init.py”, line 2, in
from miio.protocol import Message, Utils
File “/usr/lib/python3.6/site-packages/miio/protocol.py”, line 179, in
Const(0x2131, Int16ub),
File “/usr/lib/python3.6/site-packages/construct/core.py”, line 1894, in init
super(Const, self).init(subcon)
File “/usr/lib/python3.6/site-packages/construct/core.py”, line 291, in init
raise TypeError(“subcon should be a Construct field”)
TypeError: subcon should be a Construct field
They worked in 0.61
But how do you ask Alexa for the temperature? I have tried “Alexa, what is the office temperature” but it replies “Office doesn’t support that”.
My Samsung TV-UE46ES5700 is not working anymore with that update. What was changed for the samsung tvs exactly?
It should be fixed in the next version:
Did you ever get your GE 28177 working properly again with Home Assistant? I’m looking at purchasing one or two, but only if they are working properly in the current release (101.3)…
Yep. They got fixed in the next update IIRC. Been working fine ever since.
