Is everyone ok with this update? Half of my lights just stopped responding (mostly fibaro dimmer 2). I can switch them on/off manually. They do report the state back to HA. But turning them on or off from HA - nothing happens (from the frontend or the rules). This is what i see in the logs
2018-01-29 18:45:15.129 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Dimming Duration - 5 - 2 - 255
2018-01-29 18:45:15.129 Detail, Node003, Refreshed Value: old value=255, new value=255, type=byte
2018-01-29 18:45:15.129 Detail, Node003, Changes to this value are not verified
2018-01-29 18:45:15.129 Detail, Node003, Notification: ValueChanged
2018-01-29 18:45:15.131 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 2 - 255
2018-01-29 18:45:15.131 Info, Node003, SwitchMultilevel::Set - Setting to level 255
2018-01-29 18:45:15.131 Info, Node003, Duration: Default
2018-01-29 18:45:15.131 Detail, Node003, Queuing (Send) MultiChannel Encapsulated (instance=2): SwitchMultilevelCmd_Set (Node=3): 0x01, 0x0f, 0x00, 0x13, 0x03, 0x08, 0x60, 0x0d, 0x01, 0x02, 0x26, 0x01, 0xff, 0xff, 0x25, 0xff, 0x7b
2018-01-29 18:45:15.131 Detail, Node003, Queuing (Send) MultiChannel Encapsulated (instance=2): SwitchMultilevelCmd_Get (Node=3): 0x01, 0x0d, 0x00, 0x13, 0x03, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x26, 0x02, 0x25, 0x0a, 0x81
2018-01-29 18:45:15.153 Detail,
2018-01-29 18:45:15.153 Info, Node003, Sending (Send) message (Callback ID=0xff, Expected Reply=0x13) - MultiChannel Encapsulated (instance=2): SwitchMultilevelCmd_Set (Node=3): 0x01, 0x0f, 0x00, 0x13, 0x03, 0x08, 0x60, 0x0d, 0x01, 0x02, 0x26, 0x01, 0xff, 0xff, 0x25, 0xff, 0x7b
2018-01-29 18:45:15.162 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-01-29 18:45:15.162 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2018-01-29 18:45:15.178 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0xff, 0x00, 0x00, 0x02, 0x16
2018-01-29 18:45:15.179 Detail, Node003, ZW_SEND_DATA Request with callback ID 0xff received (expected 0xff)
2018-01-29 18:45:15.179 Info, Node003, Request RTT 25 Average Request RTT 24
2018-01-29 18:45:15.179 Detail, Expected callbackId was received
2018-01-29 18:45:15.179 Detail, Expected reply was received
2018-01-29 18:45:15.179 Detail, Message transaction complete
2018-01-29 18:45:15.179 Detail, Node003, Removing current message
2018-01-29 18:45:15.179 Info, Node003, Sending (Send) message (Callback ID=0x0a, Expected Reply=0x04) - MultiChannel Encapsulated (instance=2): SwitchMultilevelCmd_Get (Node=3): 0x01, 0x0d, 0x00, 0x13, 0x03, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x26, 0x02, 0x25, 0x0a, 0x81
2018-01-29 18:45:15.188 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-01-29 18:45:15.188 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2018-01-29 18:45:15.204 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x0a, 0x00, 0x00, 0x03, 0xe2
2018-01-29 18:45:15.204 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x0a received (expected 0x0a)
2018-01-29 18:45:15.204 Info, Node003, Request RTT 25 Average Request RTT 24
2018-01-29 18:45:15.204 Detail, Expected callbackId was received
2018-01-29 18:45:15.216 Detail, Node003, Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x03, 0x07, 0x60, 0x0d, 0x02, 0x01, 0x26, 0x03, 0x37, 0x8e
2018-01-29 18:45:15.216 Info, Node003, Response RTT 36 Average Response RTT 35
2018-01-29 18:45:15.216 Info, Node003, Received a MultiChannelEncap from node 3, endpoint 2 for Command Class COMMAND_CLASS_SWITCH_MULTILEVEL
2018-01-29 18:45:15.216 Info, Node003, Received SwitchMultiLevel report: level=55
2018-01-29 18:45:15.216 Detail, Node003, Refreshed Value: old value=0, new value=55, type=byte
2018-01-29 18:45:15.216 Detail, Node003, Changes to this value are not verified
2018-01-29 18:45:15.216 Detail, Node003, Expected reply and command class was received
2018-01-29 18:45:15.216 Detail, Node003, Message transaction complete
2018-01-29 18:45:15.217 Detail,
2018-01-29 18:45:15.217 Detail, Node003, Removing current message
2018-01-29 18:45:15.217 Detail, Node003, Notification: ValueChanged
2018-01-29 18:45:24.457 Info, Node010, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Dimming Duration - 5 - 1 - 255
2018-01-29 18:45:24.457 Detail, Node010, Initial read of value
2018-01-29 18:45:24.457 Detail, Node010, Notification: ValueChanged
2018-01-29 18:45:24.459 Info, Node010, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 0
2018-01-29 18:45:24.459 Info, Node010, SwitchMultilevel::Set - Setting to level 0
2018-01-29 18:45:24.459 Info, Node010, Duration: Default
2018-01-29 18:45:24.459 Detail, Node010, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Set (Node=10): 0x01, 0x0f, 0x00, 0x13, 0x0a, 0x08, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x01, 0x00, 0xff, 0x25, 0x0b, 0x7a
2018-01-29 18:45:24.459 Detail, Node010, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Get (Node=10): 0x01, 0x0d, 0x00, 0x13, 0x0a, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x02, 0x25, 0x0c, 0x8d
2018-01-29 18:45:24.485 Detail,
2018-01-29 18:45:24.485 Info, Node010, Sending (Send) message (Callback ID=0x0b, Expected Reply=0x13) - MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Set (Node=10): 0x01, 0x0f, 0x00, 0x13, 0x0a, 0x08, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x01, 0x00, 0xff, 0x25, 0x0b, 0x7a
2018-01-29 18:45:24.494 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-01-29 18:45:24.494 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2018-01-29 18:45:24.517 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x0b, 0x00, 0x00, 0x02, 0xe2
2018-01-29 18:45:24.518 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x0b received (expected 0x0b)
2018-01-29 18:45:24.518 Info, Node010, Request RTT 32 Average Request RTT 28
2018-01-29 18:45:24.518 Detail, Expected callbackId was received
2018-01-29 18:45:24.518 Detail, Expected reply was received
2018-01-29 18:45:24.518 Detail, Message transaction complete
2018-01-29 18:45:24.518 Detail, Node010, Removing current message
2018-01-29 18:45:24.518 Info, Node010, Sending (Send) message (Callback ID=0x0c, Expected Reply=0x04) - MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Get (Node=10): 0x01, 0x0d, 0x00, 0x13, 0x0a, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x02, 0x25, 0x0c, 0x8d
2018-01-29 18:45:24.527 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-01-29 18:45:24.527 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2018-01-29 18:45:24.543 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x0c, 0x00, 0x00, 0x02, 0xe5
2018-01-29 18:45:24.543 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x0c received (expected 0x0c)
2018-01-29 18:45:24.544 Info, Node010, Request RTT 24 Average Request RTT 26
2018-01-29 18:45:24.544 Detail, Expected callbackId was received
2018-01-29 18:45:24.556 Detail, Node010, Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x0a, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x03, 0x00, 0xb3
2018-01-29 18:45:24.556 Info, Node010, Response RTT 37 Average Response RTT 38
2018-01-29 18:45:24.556 Info, Node010, Received a MultiChannelEncap from node 10, endpoint 1 for Command Class COMMAND_CLASS_SWITCH_MULTILEVEL
2018-01-29 18:45:24.556 Info, Node010, Received SwitchMultiLevel report: level=0
2018-01-29 18:45:24.556 Detail, Node010, Refreshed Value: old value=0, new value=0, type=byte
2018-01-29 18:45:24.557 Detail, Node010, Changes to this value are not verified
2018-01-29 18:45:24.557 Detail, Node010, Expected reply and command class was received
2018-01-29 18:45:24.557 Detail, Node010, Message transaction complete
2018-01-29 18:45:24.557 Detail, Node010, Removing current message
2018-01-29 18:45:24.557 Detail, Node010, Notification: ValueChanged
