Hello Guys,
i’ve updated to version 0.63 few hours ago, and, after that, i’m not anymore able to load home assitant…
I’ve updated from the front end, i’ve tried to reboot, power cycle and all basic stuff, but, so far, no way to get the front end running.
here some details:
core-ssh:~# hassio homeassistant check
"result": "error",
"message": "starting version 3.2.4\nTraceback (most recent call last):\n File \"/usr/lib/python3.6/runpy.py\", line 193, in _run_module_as_main\n \"__main__\", mod_spec)\n File \"/usr/lib/python3.6/runpy.py\", line 85, in _run_code\n exec(code, run_globals)\n File \"/usr/lib/python3.6/site-packages/homeassistant/__main__.py\", line 376, in <module>\n sys.exit(main())\n File \"/usr/lib/python3.6/site-packages/homeassistant/__main__.py\", line 351, in main\n args = get_arguments()\n File \"/usr/lib/python3.6/site-packages/homeassistant/__main__.py\", line 90, in get_arguments\n import homeassistant.config as config_util\n File \"/usr/lib/python3.6/site-packages/homeassistant/config.py\", line 23, in <module>\n from homeassistant.core import callback, DOMAIN as CONF_CORE\n File \"/usr/lib/python3.6/site-packages/homeassistant/core.py\", line 22, in <module>\n from async_timeout import timeout\nImportError: cannot import name 'timeout'\n"
core-ssh:~#
and more:
core-ssh:~# hassio ha info
"result": "ok",
"data": {
"version": "0.63",
"last_version": "0.63",
"image": "homeassistant/raspberrypi3-homeassistant",
"custom": false,
"boot": true,
"port": 8123,
"ssl": false,
"watchdog": true,
"startup_time": 600
core-ssh:~# hassio
and again, some details extracted from the log:
2018-02-11 17:34:20 ERROR (SyncWorker_6) [xiaomi_gateway] No data in response from hub None
2018-02-11 17:34:27 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-02-11 17:37:45 ERROR (SyncWorker_15) [xiaomi_gateway] No data in response from hub None
2018-02-11 17:39:44 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport (error status in uv_stream_t.read callback)
OSError: [Errno 113] Host is unreachable
is there a way to recover or, in order to avoid to waste time, is better to start from scratch (new installation)?
thanks a lot for your inputs!
