So I’ve just tried to update to 0.65.6 with my normal scripts and HA doesn’t start back up again.
Upon running the update process manually via SHH to my pi3, I’m greeted with a lot of red text during the uninstall process.
I don’t know what is going on, or what has changed, but something is broken, and now HA will not start.
Installing collected packages: homeassistant
Found existing installation: homeassistant 0.65.5
Uninstalling homeassistant-0.65.5:
Exception:
File "/srv/homeassistant/lib/python3.5/shutil.py", line 544, in move
os.rename(src, real_dst)
PermissionError: [Errno 13] Permission denied: '/srv/homeassistant/lib/python3.5/site-packages/homeassistant-0.65.5.dist-info/RECORD' -> '/tmp/pip-rpdd36vh-uninstall/srv/homeassistant/lib/python3.5/site-packages/homeassistant-0.65.5.dist-info/RECORD'
File "/srv/homeassistant/lib/python3.5/site-packages/pip/basecommand.py", line 215, in main
status = self.run(options, args)
File "/srv/homeassistant/lib/python3.5/site-packages/pip/commands/install.py", line 342, in run
prefix=options.prefix_path,
File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py", line 778, in install
requirement.uninstall(auto_confirm=True)
File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_install.py", line 754, in uninstall
paths_to_remove.remove(auto_confirm)
File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_uninstall.py", line 115, in remove
renames(path, new_path)
File "/srv/homeassistant/lib/python3.5/site-packages/pip/utils/__init__.py", line 267, in renames
shutil.move(old, new)
File "/srv/homeassistant/lib/python3.5/shutil.py", line 559, in move
os.unlink(src)
and this is what I get when I start HA then check the status via systemctl
● [email protected] - Home Assistant
Loaded: loaded (/etc/systemd/system/[email protected]; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2018-03-23 00:34:20 AEDT; 1min 19s ago
Process: 1398 ExecStart=/srv/homeassistant/bin/hass -c /home/homeassistant/.homeassistant (code=exited, status=203/EXEC)
Main PID: 1398 (code=exited, status=203/EXEC)
Mar 23 00:34:20 raspberrypi systemd[1]: Started Home Assistant.
Mar 23 00:34:20 raspberrypi systemd[1398]: [email protected]: Failed at step EXEC spawning /srv/homeassistant/bin/hass: No such file or directory
Mar 23 00:34:20 raspberrypi systemd[1]: [email protected]: Main process exited, code=exited, status=203/EXEC
Mar 23 00:34:20 raspberrypi systemd[1]: [email protected]: Unit entered failed state.
Mar 23 00:34:20 raspberrypi systemd[1]: [email protected]: Failed with result 'exit-code'.
