The first is just an observation. I haven’t tried it yet, but I don’t see how the new light group differs from just putting your lights in groups. I have groups configured for my lights and they seem to work exactly like the pictures/description of the new light groups work… I have always had entries in my groups.yaml that look like this:
I can set the colour for all lights by changing the group, etc.
The second thing is that it seems that some information is no longer being passed to my influxdb db and therefore my grafana graphs are not working for everything I’l like to graph. Specifically, sensor.load_15m, sensor.load_1m, sensor.load_5m are not being written to influxdb any longer. My influxdb config is using all the defaults and therefore I only have influxdb: in my configuration.yaml.
Does anyone know why some things would stop writing to influxdb with hass 0.65?
Influx stopped working for me as well. I’m getting the following traceback when HA is setting it up:
2018-03-23 01:57:35 ERROR (MainThread) [homeassistant.setup] Error during setup of component influxdb
File "/opt/homeassistant/lib/python3.6/site-packages/homeassistant/setup.py", line 145, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/lib64/python3.6/asyncio/futures.py", line 327, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib64/python3.6/asyncio/tasks.py", line 250, in _wakeup
future.result()
File "/usr/lib64/python3.6/asyncio/futures.py", line 243, in result
raise self._exception
File "/usr/lib64/python3.6/concurrent/futures/thread.py", line 56, in run
File "/opt/homeassistant/lib/python3.6/site-packages/homeassistant/components/influxdb.py", line 95, in setup
from influxdb import InfluxDBClient, exceptions
File "/opt/homeassistant/lib/python3.6/site-packages/influxdb/__init__.py", line 9, in <module>
from .client import InfluxDBClient
File "/opt/homeassistant/lib/python3.6/site-packages/influxdb/client.py", line 16, in <module>
from six.moves import xrange
ModuleNotFoundError: No module named 'six.moves'; 'six' is not a package
This may be unrelated to the 0.65 upgrade, but is anyone else having issues with the Dark Sky sensor? I noticed my sensor data was not updating when I was on 065.3 and now that I have upgraded to 065.6 my sensor icons have disappeared from my UI.
I’d appreciate any suggestions for troubleshooting this as I can see any issues in the logs.
@finity - thanks - that’s good to know I’ll keep checking at my end. My next guess is maybe I’m making too many calls and am blocked at the DarkSky end. I’ll investigate…
Thanks for the suggestion. I remembered that I also enabled the PiHole Hassio add on recently. Running this on Hassio seems to cause this issue while running PiHole on a different host works fine. At least I know what I need to troubleshoot now!!
Same here. Though only the brightness for ‘white’ lights are not responding. The ‘RGBWW’ still work fine.
Then, brightness can be changed through the MiLight app directly.
