Same issue trying to update 65.3 to 65.4 on PI 3 panic: interface conversion: interface is nil, not string
**Update now working deleted some snapshots maybe disk space or just internet issues ? **
Canāt get Netatmo to work on 0.65. It keeps coming up with an invalid config but nothing changed in my config since 0.64 regarding Netatmo. Ideas? Or is this a 0.65 bug?
Hi, Efergy instant readings is not working anymore. error is:
Could not update status for Energy Usage
9:04 PM components/sensor/efergy.py (WARNING).
However the other Energy sensors like sensor.energy_consumed, sensor.energy_cost are working. Only the sensor.energy_usage does not work. Any ideas? Thanks
How does rename entity work?
The name field is a friendly_name field not entity_id
Renaming an entity using the new UI state dialog is - to my knowledge - only possible for entities that have been added to the entity registry. In my case, itās the Hue light bulbs.
The entered new name is added as ānameā attribute to an entry of the entity registry. The text can still be overriden by a friendly_name attribute in customize.yaml.
I modified the entuty_registry, for a hue bulb, name field, this changes only the friendly name
So thus is wrong?
Where is this new UI where you can change the entity_id?
Since upgrading from 0.64 to 0.65.3 my log is flooded with Telegram errors. I get this message 5 or 6 times a minute
2018-03-15 07:19:31 ERROR (MainThread) [homeassistant.components.telegram_bot.polling] wrong status 409
Iām using polling now and I donāt see that errors in my log. Now that youāve mentioned it, I recall I did see such errors in earlier version. I guess thatās why I moved to webhooks.
I use ha 0.65.5 on hassbian and raspbian. just install telegram polling yesterday and it works so fine.
Mine is just try to use telegram bot from Mr. masterkenobi share
Sorry I lost track of this issue
This is my current config
google_assistant:
project_id: homeassistant
client_id: CLIENTID
access_token: TOKEN
agent_user_id: [email protected]
api_key: APIKEY
exposed_domains:
- switch
- light
- group
entity_config:
sensor.temperature_158d0001fa985e:
expose: true
sensor.temperature_158d0001fa9917:
expose: true
Is this correct? When I type/do the following on Google Assistant via app āsync my devicesā it replies āAn error occured while syncing my test appā
Also when I say āWhat is my bedroom temperatureā
It says āSorry I am unable to reach bedroom right nowāā¦
I can see the API connection making a call
2018-03-20 11:44:08 INFO (MainThread) [homeassistant.components.http.view] Serving /api/google_assistant to 66.249.82.137 (auth: False)
The IP being a google proxyā¦
So is the setup correct or I need to make changes since 0.65 ???
google assistant component is not support sensor domain but support climate domain. By putting some domain that not support by google assistant will cause account link failed or end up with see no devices in your google assistant app. Try putting only support domain for google assistant. each domain that you put in google assistant app. You also need to put in entity_config for that specific devices.
Currently, the following domains are available to be used with Google Assistant, listed with their default types:
group (on/off)
input boolean (on/off)
scene (on)
script (on)
switch (on/off)
fan (on/off)
light (on/off/brightness/rgb color/color temp)
cover (on/off/set position (via set brightness))
media_player (on/off/set volume (via set brightness))
climate (temperature setting)
I leave input_boolean away as well. As putting in input_boolean, google assistant can not discover input_boolean anyway.
Same here, running 0.65.5 now and still the same problem. Nothing in the logs suggesting itās not working
edit released people may think Iām referring to the google assistant problem, Iām actually referring to the Yeelight problem mentioned by @brahmafear
I downgraded to 0.64.3 and itās working fine again.
Thanksā¦ What would I need to change in my above code to make it climate? Something like?
google_assistant:
client_id: CLIENTID
access_token: TOKEN
api_key: APIKEY
exposed_domains:
- switch
- light
- group
- climate
entity_config:
climate.temperature_158d0001fa985e:
expose: true
climate.temperature_158d0001fa9917:
expose: true
Must be something else as how will the sensors tie to climate?
This is what home assistant support under climate component
The Google Assistant component does not support temperature sensors. Weāre still waiting for Google to add support for this. In the meanwhile, you can configure a generic thermostat to have Google Assistant read your temperature sensor.
What should be the heater: in this case? create fake switch or something?
climate:
- platform: generic_thermostat
heater: switch.study_heater
target_sensor: sensor.study_temperature
Anyone having a complete example will be really helpfulā¦
Have done the following but google assistant still doesnāt like it
google_assistant:
client_id: CLIENTID
access_token: TOKEN
api_key: APIKEY
exposed_domains:
- switch
- light
- group
- climate
entity_config:
switch.living_room:
name: Living Room Temperature
switch.second_bedroom:
name: Bedroom Temperature
climate:
heater: switch.living_room
target_sensor: sensor.temperature_158d0001fa985e
heater: switch.second_bedroom
target_sensor: sensor.temperature_158d0001fa9917
After update to 65.5, my Lifx bulbs are gone. I canāt see them in the dev states tab and there are no errors in my log concerning Lifx. Sort of stuck on where to look to for a fix.
Could be related to the Yellight problem a few of us are having?
For anyone wondering about the easiest way to this release of HA running on Ubuntu 16.04 LTS, this is the way I upgraded Python to make it work.
python3 --version # 16.04 LTS is Python 3.5.2
sudo add-apt-repository ppa:jonathonf/python-3.5
sudo apt-get update
sudo apt upgrade
python3 --version # Python 3.5.3+
Use at your own risk, compile it from source using one of various tutorials or wait until 18.04 LTS.
