0.69: Matrix Chatbot, PostNL, Social Blade, Xiaomi Mijia sensors
![](upload://5kOvjsYhRsnfndguwx6ppcHxcWU.png)
Not much time to write a great into this time as we’re hanging out at PyCon! Some fixes for the Hue and Wink colors thanks to @amelchio. Initial foundation for users has landed, it’s not anywhere near usable. We’ll keep hacking on it. Google Assistant for Home Assistant Cloud now supports room hints. This will cause Google Assistant put the devices in the right groups when you link your account.
New Platforms
If you need help…
…don’t hesitate to use our very active forums or join us for a little chat. The release notes have comments enabled but it’s preferred if you use the former communication channels. Thanks.
Reporting Issues
Experiencing issues introduced by this release? Please report them in our issue tracker. Make sure to fill in all fields of the issue template.
Breaking Changes
  • Pollen.com: Added attributes on top 3 allergens. This caused attribute names primary_allergen_genus, primary_allergen_name and primary_allergen_type to be suffixed with _1 (@bachya - #14018) (sensor.pollen docs) (breaking change)
  • Add Sonos device attribute with grouping information. The media_player.sonos attribute is_coordinator has been removed; the new attribute sonos_group (listing all group members, coordinator first) can be used instead. (@amelchio - #13553) (media_player.sonos docs) (breaking change)
  • Re-implement HomematicIP cloud to async. Change of configuration schema: name is optional and cannot be empty. Remove of state attributes for sensors. Remove of additional sensor to show state of all found components (@mxworm - #13468) (homematicip_cloud docs) (sensor.homematicip_cloud docs) (breaking change)
  • System log: make firing event optional (@balloob - #14102) (system_log docs) (breaking change)
  • Converts RainMachine to hub model (part 2) (@bachya - #14225) (rainmachine docs) (switch.rainmachine docs) (breaking change)
  • Homekit: Changed device_class requirement Humidity Sensor (@cdce8p - #14277) (homekit docs) (breaking change)
  • The sensor unit lux has been replaced with lx for consistency. That covers the following sensor platforms: homematic, isy994, miflora, mysensors, tahoma, vera and template sensors. To add light sensors for the HomeKit component the device_class changed to illuminance. (@cdce8p - #14282) (sensor docs) (breaking change)
  • The Matrix notification platform now depends on the the new Matrix component. Please see the documentation for how to configure the Matrix component. (@tinloaf - #13355) (matrix docs) (notify docs) (breaking change) (new-platform)
  • Move RainMachine to component/hub model and remove Remote API. (@bachya - #14085 - #14225) (rainmachine docs) (switch.rainmachine docs) (breaking change) (new-platform)
# New rainmachine config
rainmachine:
  ip_address: 192.168.1.100
  password: abc123
  switches:
    zone_run_time: 240
Beta Fixes
All changes
This is a companion discussion topic for the original entry at https://www.home-assistant.io/blog/2018/05/11/release-69/
Looks like the sabnzbd conversion from sensor to component didn’t make it in this pull?
Thank you @andrey-git and @perosb for what I think are big changes to z-wave
  • the return of unique IDs for the nodes, to avoid duplicate nodes being created when they have the same name, but different types
  • the ability to update the open-zwave device config from git
One issue I’ve com across on HASS.IO when I restart home assistant it does not automatically initialize my automatons I have to go into Configure -> General -> Reload Automatons
Anyone having issues with limitless led showing up in this update?
broadlink RM pro switch not working after update
I have a problem with 0.70.0b0 not all pages work, only the overview
