Today we are releasing 0.73.2 to fix a security incident. We’ve discovered that 9 months ago, with the release of Home Assistant 0.56, we misconfigured the SSL context that aiohttp used (PR). By trying to do the right thing (use an up to date cert store instead of relying on the system certs), we ended up doing the complete opposite: SSL verification was disabled for outgoing requests that were done using the shared aiohttp session. This is our fault, and not aiohttp’s faults. The impact of this is that certain integrations in Home Assistant have been susceptible to man in the middle attacks.
A man in the middle attack is when an attacker is able to inject itself between you and the server you’re communicating with, allowing it to read and alter the communication. The odds of this happening at home is very rare, yet we wanted to be transparent about this incident.
After research, the following integrations have been impacted. Although the odds are extremely small, we still suggest that if you use any of these integrations, to create new API keys or change your password.
Also impacted, but integrations are read only:
For complete transparency, the following two sets of integrations also used aiohttp to send or retrieve data. However, they either did not transmit authentication or only communicated with local devices and services.
Just upgraded from 0.73.1 to 0.73.2 and am now getting the following error message:
pi@ha:~ $ sudo service home-assistant status
● home-assistant.service - Home Assistant
Loaded: loaded (/etc/systemd/system/home-assistant.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2018-07-16 16:52:07 EDT; 233ms ago
Process: 1219 ExecStart=/srv/homeassistant/bin/hass -c /home/homeassistant/.homeassistant (code=exited, status=1/FAILURE)
Main PID: 1219 (code=exited, status=1/FAILURE)
Jul 16 16:52:07 ha hass[1219]: File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/__main__.py", line 352, in main
Jul 16 16:52:07 ha hass[1219]: args = get_arguments()
Jul 16 16:52:07 ha hass[1219]: File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/__main__.py", line 85, in get_arguments
Jul 16 16:52:07 ha hass[1219]: import homeassistant.config as config_util
Jul 16 16:52:07 ha hass[1219]: File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/config.py", line 162, in <module>
Jul 16 16:52:07 ha hass[1219]: vol.All(cv.ensure_list, [auth.AUTH_PROVIDER_SCHEMA])
Jul 16 16:52:07 ha hass[1219]: AttributeError: module 'homeassistant.auth' has no attribute 'AUTH_PROVIDER_SCHEMA'
Jul 16 16:52:07 ha systemd[1]: home-assistant.service: Main process exited, code=exited, status=1/FAILURE
Jul 16 16:52:07 ha systemd[1]: home-assistant.service: Unit entered failed state.
Jul 16 16:52:07 ha systemd[1]: home-assistant.service: Failed with result 'exit-code'.
So, what is potentially the scope of a mitm in this context? An attacker could have access to the impacted service even when the machine running Hass is not exposed to the internet? Just to this service or to more?
EDIT: It was a stupid question. It has now appeared. I read elsewhere that there is a delay before hassio gets packaged once a new release comes out.
This feels like a stupid question…
I’m running hassio on HassOS.
Should I have a notification of there being a new version?
On ResinOS I had sensor badge appear on my home page and an indication on the hassio system page with an upgrade button.
Stupid question but just want a little clarity. The integrations under “Local, so cannot be impacted”, we don’t need to change anything for those integrations then, correct?
It’s a pity you can’t simply generate new API keys for OpenALPR cloud. I asked them about it and the only way to get new ones is to (delete your old and) create a new account.
I have a question as well regarding the cloud-component: should we change our password for the Home Assistant Cloud, if yes, how?
You don’t have to change your password for Home Assistant Cloud. Your username and password were never transmitted via unverified SSL connections. Only short-lived access tokens.
