Good day. First of all thank you for this great product!
One question, once entirely migrated to this new users UI and with the API password gone; how will the components that use the API password access the system?
i.e. a saved picture for a notification an alexa custom briefing, etc.
We will change those integrations to use new auth system before we remove api_password support. That will be a long journey.
@awarecan thank you very much. So for the time being, we can migrate and the legacy API will continue to work until the future integration is complete?
I am using the new Auto and legacy api for ifttt and google assistant. It works seemlessly with those as well as the web GUI. I’m on HassOS.
Apologies for a really stupid question, but how do I display the image on my frontend with the new push camera?
EDIT:
It’s simply
camera.whatever_you_called_it
also, if someone else is struggling with the motioneye command, it should be
curl -X POST -F "image=@%f" http://my.hass.server.com:8123/api/camera_push/camera.WHAT_EVER_YOU_CALLED_IT
Didn’t think that was very clear in the docs.
ERROR during TUYA Setup
2018-07-21 19:36:19 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform tuya
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 129, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for
return fut.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/home/homeassistant/.homeassistant/custom_components/switch/tuya.py", line 48, in setup_platform
config.get(CONF_LOCAL_KEY)
File "/srv/homeassistant/lib/python3.5/site-packages/pytuya/__init__.py", line 249, in __init__
super(OutletDevice, self).__init__(dev_id, address, local_key, dev_type)
File "/srv/homeassistant/lib/python3.5/site-packages/pytuya/__init__.py", line 146, in __init__
self.local_key = local_key.encode('latin1')
AttributeError: 'NoneType' object has no attribute 'encode'
If you want to use the tuya component in 0.74? If so, I think you should delete the tuya component in custom_component file. As I known, it will override the built-in one.
Thank you, that was it, I forgot I had that setup and disabled during the trial days.
Is there any chance of getting the statistics from the switches?
Sorry, it doesn’t support currently
Thanks for making this a simple implementation.
With tuya components is there any way to remove the entity picture to use an icon instead?
Where do you buy Tuya products from?
Amazon is a good place in the UK don’t know for rest of the world.
I’m getting this error for HDMI-CEC.
Error during setup of component hdmi_cec
File "/usr/local/lib/python3.6/site-packages/homeassistant/setup.py", line 146, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/hdmi_cec.py", line 182, in setup
adapter = CecAdapter(name=display_name[:12], activate_source=False)
File "/usr/local/lib/python3.6/site-packages/pycec/cec.py", line 20, in __init__
import cec
ModuleNotFoundError: No module named 'cec'
https://github.com/home-assistant/home-assistant/issues/15406
I’m running Home Assistant from a Docker Container on a Synology nas.
I’ve pulled the 0.74.0 image last night and gave it a run.
Everything is working beautifully but I get some warnings in the dev-info
panel, after enabling the auth:
component.
My configuration.yaml
is looking like this:
homeassistant:
# Name of the location where Home Assistant is running
name: !secret homeassistant_config_location_name
# Location required to calculate the time the sun rises and sets
latitude: !secret homeassistant_config_latitude
longitude: !secret homeassistant_config_longitude
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: !secret homeassistant_config_time_zone
auth_providers:
- type: homeassistant
# # Uncomment next line if you want to enable legacy API password support
# - type: legacy_api_password
auth:
… and those pesky messages, are looking like this:
I own 3 x iPad Mini and 2 x iPhone, and on every one of them I went on and logged in with a previously created user & pass, then logged out and then back in without a hitch. Every time I clear the log, then issue a command (lets say, turn on a light) from an Apple device, those messages come right back (although the command executes fine).
What can I do to make those messages go away ? What am I doing wrong ?, Does someone else is having this issue ?, involving not only Apple devices, but it seems it affects cameras as well.
Thank You.
I am getting similar results,
0.74 here, configured it with new auth providers (kept the api_pass provider) but I receive similar log messages as above "Please change to use bearer token access … ". I have 2 users - me and my wife, both using the iOS app on iPhone, but when using the app, we get persistent notification for Failed Login Attempts from IP …which comes after 1 second of reloading from the HA logo screen. These notifications come if the iOS app was not used like for about 30 mins. (token expires I guess). If using the browser instead is fine and no such notifications. Maybe the iOS app needs a new version to accommodate the new auth features? Or I am missing something.
No the iOS dev is aware and has fixed this issue for the next release. Not just you.
I finally had some time for an upgrade from 0.56.2. But, after the normal procedure with “sudo pip3 install --upgrade homeassistant” I still have 0.56.2? The installation logs shows 0.74 though… What has changes? This is running on a RPI 3 with a lot of other things (MQTT, Node-Red, Unifi) so I guess that a HASS.io installation is not my best choice?
/Joakim
