I am getting the same popup every time I reload the page on my Mac. Even without adding the auth part to my config.
Edit: I am using the lovelace UI
Unable to click any sensors in the web UI after the update, nothing pops up. Also missing stuff from the config sections. It does work in the mobile browser howeverā¦not PC. Also getting the save password popup every time (have not added the new auth config).
nothing works, log is full with syntax errors. wtf
2018-08-18 12:54:27 ERROR (MainThread) [homeassistant.components.notify] Unknown notification service specified
Aug 18 12:54:27 raspberrypi hass[3005]: (standard_in) 1: syntax error
Aug 18 12:54:28 raspberrypi hass[3005]: 2018-08-18 12:54:28 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of switch.mqtt. Setup failed for dependencies: mqtt
Aug 18 12:54:28 raspberrypi hass[3005]: 2018-08-18 12:54:28 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform switch.mqtt: Could not setup all dependencies.
Aug 18 12:54:28 raspberrypi hass[3005]: (standard_in) 1: syntax error
Aug 18 12:54:30 raspberrypi hass[3005]: 2018-08-18 12:54:30 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
Did you update your configuration? There was a breaking change for the embedded MQTT broker
yes, all updated
x.0 releasesā¦never works
I have not added anything to configuration.yaml, but I have still the same problem as you.
This problem has been fixed. Will be in next update.
Please can someone help me?
I have updated using Hassio however the version still shows as 0.75.2 and i get the following error:
The following components and platforms could not be set up:
hassio
Please check your config.
Is it just me or is Rename Node gone from the Zwave control panel?
EDIT: Also the question marks in the zwave control panel are broken too. They donāt display any help text.
EDIT2: Reverting back to 0.75.3 didnāt work either. I know this was just working too. And Iām still getting the save login popup like i didnāt properly revert back to 0.75.3 but the info screen says 0.75.3. Anyone have any ideas?
Updating to 0.76.0 gave this:
I
And Iāve lost the āHistoryā tab.
Your database migration not success, if nothing important in history, you can just delete the db file. HA will recreate one in next startup.
Or, you have to manual modify your database schema.
So do you suggest to wait until 0.76.1 is released before upgrading from 0.75.x?
Only to avoid annoying SAVE LOGIN popup if you donāt enable new auth
I reverted to 0.75.3 and now I canāt log on.
My duckdns url says ā404 file not foundā and https://hassio.local:8123 hangs on āloading dataā
OK it sorted itself out after I did the update to 0.76.0 from the terminal.
Same here - seeing a āDo you want to save this loginā popup on every page refresh. Doesnāt matter what I click it comes back every time.
And Iām not using embedded mqtt (using mosquitto running on its own).
As I answered in previous comment, this is bug and have been fixed. Please wait next update.
Confirmed here too, running Maria DB on Synology and no problems then i upgrade to 0.76 and recorder is now broken and any other component using recorder!!!
2018-08-19 11:58:01 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (_mysql_exceptions.OperationalError) (1296, āGot error 64 āTemp file write failureā from InnoDBā) [SQL: āALTER TABLE events ADD COLUMN context_id CHARACTER(36)ā] (Background on this error at: http://sqlalche.me/e/e3q8)
mine upgraded fine and also using mariadb.
