After a 0.77.2 update, my Xiaomi button automation stopped working. I’m using zigbee2mqtt and everything else functions fine. The topic appears when I press the button in mqtt:
2018-09-01 08:05:43 WARNING (MainThread) [homeassistant.components.http] legacy_api_password support has been enabled. If you don't require it, remove the 'api_password' from your http config.
2018-09-01 08:05:55 WARNING (MainThread) [homeassistant.loader] You are using a custom component for climate.broadlink which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-09-01 08:05:55 WARNING (MainThread) [homeassistant.loader] You are using a custom component for media_player.broadlink which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-09-01 08:06:05 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-09-01 08:10:02 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
File "uvloop/handles/stream.pyx", line 609, in uvloop.loop.UVStream._on_eof
File "uvloop/sslproto.pyx", line 171, in uvloop.loop._SSLPipe.feed_ssldata
File "/usr/local/lib/python3.6/ssl.py", line 689, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:841)
2018-09-01 08:10:02 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: WRONG_VERSION_NUMBER
File "uvloop/sslproto.pyx", line 504, in uvloop.loop.SSLProtocol.data_received
File "uvloop/sslproto.pyx", line 204, in uvloop.loop._SSLPipe.feed_ssldata
