As the title says… 0.80 borked my Zwave; it wrote a bunch of crap into the zwcfg*.xml file; weird characters and corrupted it.
Now after rolling back to a backup I have many switches; mostly HomeSeer; that will not respond. Excluding and re-including also doesn’t work. Power cycle doesn’t work.
It’s really odd; seems HA puts them into a hung state almost immediately after startup.
Rolling back to 78 or 79 doesn’t bring it back either. Deleting the zwcfg*.xml and letting it regenerate doesn’t solve the issue with the HomeSeer switches.
v 0.8.0 did similar to my stuff. I had to physically power recycle the devices. In hindsight I think I just should have hit the main breaker to the homestead and dealt with it in one fell swoop.
No homeseer in this homestead… I went with wink/z-wave this time. The hardware issues I’m having today are with wink hubs, ip cameras and amazon firesticks. Routers, other servers (plex, print, etc) are all okay.
Now this is interesting… during remove node of one of the HomeSeer… what are all those mystery values?
018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596022456321}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596022456344}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596022456360}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596030844976}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596030844993}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596030861316}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596031713283}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596031762433}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596031762454}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596031762470}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596032106500}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596032106513}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596032106536}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596032106545}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596032106564}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596032106582}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596032106600}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596032106616}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596032106628}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596032106646}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596032417799}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596032417815}) on node 118
2018-10-23 10:23:00 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057596032417831}) on node 118
I have tried to use a backup of the entry id 56 data in both zwcfg_0xecd54037.xml and core.entity_registry, but still Z-wave entity id 56 is not listed in /dev-state.
in /config/entity_registry the entity is listed as [unavailable]
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594982252544}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594990673924}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594982465538}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594982465554}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594982465571}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594982465666}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594982465682}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594982465699}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594982465794}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594982465810}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594982465827}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594982465858}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594982465874}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594982465891}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594982466048}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594990854680}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594991575041}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594991575062}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594991575078}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594987675668}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594987675686}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594987675697}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594987675713}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594987675732}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594987675745}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594987675764}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594987675780}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594987675798}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594987675812}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594983497729}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594983497745}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594983497761}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594983497905}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594991919108}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594991919121}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594991919144}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594991919153}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594991919172}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594991919190}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594991919208}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594991919224}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594991919236}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594991919254}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594992230407}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594992230423}) on node 56
2019-03-06 21:51:26 WARNING (Dummy-10) [openzwave] Z-Wave Notification ValueRemoved for an unknown value ({'id': 72057594992230439}) on node 56
