Getting the following errors with all my devices missing:
Setup failed for remote: Could not set up all dependencies.
3:54 PM setup.py (ERROR)
Unable to set up dependencies of remote. Setup failed for dependencies: group
Setup failed for lock: Could not set up all dependencies.
Unable to set up dependencies of lock. Setup failed for dependencies: group
Setup failed for ios: Could not set up all dependencies.
Unable to set up dependencies of ios. Setup failed for dependencies: device_tracker
Setup failed for light: Could not set up all dependencies.
Unable to set up dependencies of light. Setup failed for dependencies: group
Setup failed for fan: Could not set up all dependencies.
Unable to set up dependencies of fan. Setup failed for dependencies: group
Setup failed for device_tracker: Could not set up all dependencies.
Unable to set up dependencies of device_tracker. Setup failed for dependencies: group
Setup failed for script: Could not set up all dependencies.
Unable to set up dependencies of script. Setup failed for dependencies: group
Setup failed for switch: Could not set up all dependencies.
Unable to set up dependencies of switch. Setup failed for dependencies: group
Setup failed for cover: Could not set up all dependencies.
Unable to set up dependencies of cover. Setup failed for dependencies: group
Setup failed for automation: Could not set up all dependencies.
Unable to set up dependencies of automation. Setup failed for dependencies: group
Setup failed for group: Invalid config.
3:54 PM config.py (ERROR)
Invalid config for [cover.mqtt]: Set position topic must be set together with get position topic.. Got OrderedDict([('platform', 'mqtt'), ('name', 'Basement Living Room Vent'), ('retain', True), ('command_topic', 'smartthings/Vent - Basement Living Room/switch/cmd'), ('state_topic', 'smartthings/Vent - Basement Living Room/switch/state'), ('state_open', 'on'), ('state_closed', 'off'), ('payload_open', 'on'), ('payload_close', 'off'), ('set_position_topic', 'smartthings/Vent - Basement Living Room/level/cmd'), ('tilt_command_topic', 'smartthings/Vent - Basement Living Room/level/cmd'), ('tilt_s.... (See ?, line ?). Please check the docs at https://home-assistant.io/components/cover.mqtt/
Invalid config for [cover.mqtt]: Set position topic must be set together with get position topic.. Got OrderedDict([('platform', 'mqtt'), ('name', 'Basement Kitchen Vent'), ('retain', True), ('command_topic', 'smartthings/Vent - Basement Kitchen/switch/cmd'), ('state_topic', 'smartthings/Vent - Basement Kitchen/switch/state'), ('state_open', 'on'), ('state_closed', 'off'), ('payload_open', 'on'), ('payload_close', 'off'), ('set_position_topic', 'smartthings/Vent - Basement Kitchen/level/cmd'), ('tilt_command_topic', 'smartthings/Vent - Basement Kitchen/level/cmd'), ('tilt_status_topic', 'smart.... (See ?, line ?). Please check the docs at https://home-assistant.io/components/cover.mqtt/
Invalid config for [cover.mqtt]: Set position topic must be set together with get position topic.. Got OrderedDict([('platform', 'mqtt'), ('name', 'Spare Room Vent'), ('retain', True), ('command_topic', 'smartthings/Vent - Spare Room/switch/cmd'), ('state_topic', 'smartthings/Vent - Spare Room/switch/state'), ('state_open', 'on'), ('state_closed', 'off'), ('payload_open', 'on'), ('payload_close', 'off'), ('set_position_topic', 'smartthings/Vent - Spare Room/level/cmd'), ('tilt_command_topic', 'smartthings/Vent - Spare Room/level/cmd'), ('tilt_status_topic', 'smartthings/Vent - Spare Room/level.... (See ?, line ?). Please check the docs at https://home-assistant.io/components/cover.mqtt/
Invalid config for [cover.mqtt]: Set position topic must be set together with get position topic.. Got OrderedDict([('platform', 'mqtt'), ('name', 'Master Bedroom Vent'), ('retain', True), ('command_topic', 'smartthings/Vent - Master Bedroom/switch/cmd'), ('state_topic', 'smartthings/Vent - Master Bedroom/switch/state'), ('state_open', 'on'), ('state_closed', 'off'), ('payload_open', 'on'), ('payload_close', 'off'), ('set_position_topic', 'smartthings/Vent - Master Bedroom/level/cmd'), ('tilt_command_topic', 'smartthings/Vent - Master Bedroom/level/cmd'), ('tilt_status_topic', 'smartthings/Ven.... (See ?, line ?). Please check the docs at https://home-assistant.io/components/cover.mqtt/
Invalid config for [cover.mqtt]: Set position topic must be set together with get position topic.. Got OrderedDict([('platform', 'mqtt'), ('name', 'Dining Room Vent'), ('retain', True), ('command_topic', 'smartthings/Vent - Dining Room/switch/cmd'), ('state_topic', 'smartthings/Vent - Dining Room/switch/state'), ('state_open', 'on'), ('state_closed', 'off'), ('payload_open', 'on'), ('payload_close', 'off'), ('set_position_topic', 'smartthings/Vent - Dining Room/level/cmd'), ('tilt_command_topic', 'smartthings/Vent - Dining Room/level/cmd'), ('tilt_status_topic', 'smartthings/Vent - Dining Room.... (See ?, line ?). Please check the docs at https://home-assistant.io/components/cover.mqtt/
Invalid config for [cover.mqtt]: Set position topic must be set together with get position topic.. Got OrderedDict([('platform', 'mqtt'), ('name', 'Living Room Vent'), ('retain', True), ('command_topic', 'smartthings/Vent - Living Room/switch/cmd'), ('state_topic', 'smartthings/Vent - Living Room/switch/state'), ('state_open', 'on'), ('state_closed', 'off'), ('payload_open', 'on'), ('payload_close', 'off'), ('set_position_topic', 'smartthings/Vent - Living Room/level/cmd'), ('tilt_command_topic', 'smartthings/Vent - Living Room/level/cmd'), ('tilt_status_topic', 'smartthings/Vent - Living Room.... (See ?, line ?). Please check the docs at https://home-assistant.io/components/cover.mqtt/
