82.1
adsfasdfasdfa
82.1
adsfasdfasdfa
Hello guys! Thanks for this awesome update.
I am amazed how fast lovelace UI loads now, great work!
Asus component working fine now, just a bug (maybe?) on how download/upload sensors shows data:
Both sensors shows the other’s value. In the image above, I was just downloading, at 50mbps, no upload whatsoever… Very strange.
Here is how it shows on the Asus WebUI:
Also: any adive on using track_new_devices
parameter now? I ratter set it manually for each new device.
Thanks!
Working now.
Followed advice from someone on here (sorry can’t see your post now!)
remove OwnTracks from device_tracker and put in the configuration.yaml on its own
OwnTracks:
Anyone else seeing issues with Schlage Z wave locks? Have a BE468 and a BE469. Both respond to local operation of the lock, but if I lock/unlock through Hass, the status never updates. Saw the update in the change log so I’m guessing it has something to do with that PR.
Any update on when an updated version of DenonAVR will be merged into the release? It’s been about 2 month since it got updated (https://github.com/scarface-4711/denonavr ) Would love to use my new receiver
RT-AX88U - everything works, but i cant disable track mode for new devices for it.
I also have this error with google tts since today, but I’m still on 0.81.6 (HassIO). So I think this error is not related to the new release directly.
Google changed the token.
https://github.com/home-assistant/home-assistant/issues/16905#issuecomment-442912708
Having the same issue here…
Hass works normaly, but every 2 minutes log is flooded with this message
Is it still working? Mine was only working for 10 mins, but i’m using telnet on a RT-AC66U.
I am using SSH and it works great, apart from the Download/Upload sensor data. Not sure how to set track_new_devices
now. Thanks.
Same here. Did the downgrade work for you?
Fixed in 0.83.1
node-red is not connecting to the HA.
Login attempt or request with invalid authentication from 192.168.X.X
@balloob
This error is occurring when I run an ifttt webhook:
Error executing service <ServiceCall switch.turn_off (c:4eb3ebc0579844abb7deb328c5253e54): entity_id=[‘switch.lampada’]>
File “/home/jean/apps/Homeassistant/lib/python3.5/site-packages/homeassistant/core.py”, line 1177, in _event_to_service_call
await service_handler.func(service_call)
File “/home/jean/apps/Homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_component.py”, line 177, in handle_service
self._platforms.values(), func, call
File “/home/jean/apps/Homeassistant/lib/python3.5/site-packages/homeassistant/helpers/service.py”, line 250, in entity_service_call
permission=POLICY_CONTROL
homeassistant.exceptions.Unauthorized: Unauthorized
What do you mean? denonavr
already uses the latest package available (0.7.6).
We can’t update the component if the PR (I assume you want https://github.com/scarface-4711/denonavr/pull/65) for support isn’t merged and a new version gets released on pypi.
Updated to 0.83.1 now getting failed login attempt even though I am logged in.
Update server is informing the wrong version and crashing hassio installations. I checked the server (https://s3.amazonaws.com/hassio-version/stable.json) and it’s informing 0.82.1 as the latest, even for whom is already on 0.83. So if someone proceed with the suggested upgrade it will corrupt the installation. That just happened to me.
same for me
I forced the upgrade to 0.83.1 using the following cli command, using ssh, and it fixes the problem.
hassio ha update --options version=0.83.1
