Hassio update normally takes a few hours to show up I find.
Google Home Bluetooth tracker seems amazing!
Even if it doesn’t work well enough for room-level detection, it would be an ideal way for home presence detection for all of us not using a Raspberry Pi for its Bluetooth.
Can it be manually updated? I’m desperate to see if I can get my AsusWRT working again!
It is said in the doc that some index need to be migrated and that it might take a while. Have you been patient enough?
I agree
What I’m curious about is can I still use the rpi bluetooth which detect us when on our drive and also use google home for room detection.
Is someone aware of these errors?
2018-11-29 12:59:53 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
result = coro.send(None)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 343, in _async_add_entity
raise HomeAssistantError(msg)
homeassistant.exceptions.HomeAssistantError: Entity id already exists: group.all_switches
homeassistant.exceptions.HomeAssistantError: Entity id already exists: group.calendar
Did you maybe declare a group calendar
2 times by mistake?
This release is so awesome! 17track is now an offical component and the best is, I can now finally use the fritzbox callmonitor component
Thank you really much
No, it’s an open issue with 0.83.0 waiting to be fixed…
All group_all set to initial state ‘on’ have this problem…
I also have problems with 0.83
When I restart HA I see some activity in the logs, and the last records are:
Nov 29 14:13:59 raspberrypi3 hass[31567]: 2018-11-29 14:13:59 INFO (Thread-14) [homeassistant.components.device_tracker.fritz] Successfully connected to FRITZ!Box 7560 (UI)
Nov 29 14:13:59 raspberrypi3 hass[31567]: 2018-11-29 14:13:59 INFO (Thread-14) [homeassistant.components.device_tracker.fritz] Scanning
Nov 29 14:14:02 raspberrypi3 hass[31567]: 2018-11-29 14:14:02 INFO (Thread-18) [homeassistant.components.device_tracker.fritz] Scanning
and it stops after this. Before this fritzbox tracker was scanning and leaving the log records periodically, each 5 seconds or so, but not after this update.
I also notice that some part of HA works, because it writes something into InfluxDB - I can see the changing numbers and graphs in Grafana which visualizes InfluxDB data, and it is only possible if HA is alive. But I cannot open HA in my browser.
I was patient enough to comment out sections in configuration.yaml to see what makes HA hang, and I found that OwnTracks is the culprit. This is my configuration:
device_tracker:
- platform: fritz
interval_seconds: 10
consider_home: 180
track_new_devices: yes
- platform: owntracks
max_gps_accuracy: 200
As soon as I comment out owntracks, HA starts fine.
I got problem with google tts after update to 0.83
Thu Nov 29 2018 20:47:12 GMT+0700 (Indochina Time)
Error executing service <ServiceCall tts.google_say (c:6ed4b19be7494df8970833f467b0c61f): entity_id=['media_player.home_speaker'], message=how are you>
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/core.py", line 1177, in _event_to_service_call
await service_handler.func(service_call)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/tts/__init__.py", line 137, in async_say_handle
options=options
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/tts/__init__.py", line 306, in async_get_url
engine, key, message, use_cache, language, options)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/tts/__init__.py", line 318, in async_get_tts_audio
message, language, options)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/tts/google.py", line 83, in async_get_tts_audio
token.calculate_token, part)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/srv/homeassistant/lib/python3.6/site-packages/gtts_token/gtts_token.py", line 28, in calculate_token
seed = self._get_token_key()
File "/srv/homeassistant/lib/python3.6/site-packages/gtts_token/gtts_token.py", line 57, in _get_token_key
tkk_expr = re.search(".*?(TKK=.*?;)W.*?", line).group(1)
AttributeError: 'NoneType' object has no attribute 'group'
Also for lovelace.
## Log Details (ERROR)
Thu Nov 29 2018 20:47:07 GMT+0700 (Indochina Time)
https://192.168.1.60:8123/frontend_latest/app-0fd67575.js:89:305 Uncaught TypeError: Cannot read property 'toUpperCase' of null
Thu Nov 29 2018 20:47:01 GMT+0700 (Indochina Time)
https://192.168.1.60:8123/frontend_latest/app-0fd67575.js:89:305 Uncaught TypeError: Cannot read property 'state' of undefined
Aha, thanks. Had the same issue of HA not showing the web-interface. Commenting out owntracks helped for now. Have to dig into the breaking change for owntracks, but at least HA is up and running again now.
I’m seeing the same errors.
17track is not working for me: [homeassistant.components.sensor.seventeentrack] Invalid username and password provided
Someone told me it’s related to the google calendar component… if you use it try to comment out that and restart…
No, I don’t even use Google Calendar.
I do use Owntracks and commented that out, but it won’t load the Lovelace fontend (and I can’t figure out how to disable Lovelace to go back to the old UI).
Hmm ok… so we must only wait for a fix… I was back to 0.82.1
Change “/lovelace” to “/states”
However it’s totally dead for me - starts up then just hangs -still running but nothing in the log - and that’s the chatty journalctl -fu [email protected]
log file which stops after a short while.
The database upgrade went quickly and successfully
Downgrading to 0.82 hasn’t helped
(Removed a comment RE: Google Calendar - it’s called Google and doesn’t mention calendar)
Thanks, that did it
