0.83: Fibaro Home Center Hubs, locks via voice, Traccar
This release is so awesome! 17track is now an offical component and the best is, I can now finally use the fritzbox callmonitor component :tada:
Thank you really much
No, it’s an open issue with 0.83.0 waiting to be fixed…
All group_all set to initial state ‘on’ have this problem…
I also have problems with 0.83
When I restart HA I see some activity in the logs, and the last records are:
Nov 29 14:13:59 raspberrypi3 hass[31567]: 2018-11-29 14:13:59 INFO (Thread-14) [homeassistant.components.device_tracker.fritz] Successfully connected to FRITZ!Box 7560 (UI)
Nov 29 14:13:59 raspberrypi3 hass[31567]: 2018-11-29 14:13:59 INFO (Thread-14) [homeassistant.components.device_tracker.fritz] Scanning
Nov 29 14:14:02 raspberrypi3 hass[31567]: 2018-11-29 14:14:02 INFO (Thread-18) [homeassistant.components.device_tracker.fritz] Scanning
and it stops after this. Before this fritzbox tracker was scanning and leaving the log records periodically, each 5 seconds or so, but not after this update.
I also notice that some part of HA works, because it writes something into InfluxDB - I can see the changing numbers and graphs in Grafana which visualizes InfluxDB data, and it is only possible if HA is alive. But I cannot open HA in my browser.
I was patient enough to comment out sections in configuration.yaml to see what makes HA hang, and I found that OwnTracks is the culprit. This is my configuration:
device_tracker:
  - platform: fritz
    interval_seconds: 10
    consider_home: 180
    track_new_devices: yes
  - platform: owntracks
    max_gps_accuracy: 200
As soon as I comment out owntracks, HA starts fine.
I got problem with google tts after update to 0.83
Thu Nov 29 2018 20:47:12 GMT+0700 (Indochina Time)
Error executing service <ServiceCall tts.google_say (c:6ed4b19be7494df8970833f467b0c61f): entity_id=['media_player.home_speaker'], message=how are you>
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/core.py", line 1177, in _event_to_service_call
    await service_handler.func(service_call)
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/tts/__init__.py", line 137, in async_say_handle
    options=options
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/tts/__init__.py", line 306, in async_get_url
    engine, key, message, use_cache, language, options)
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/tts/__init__.py", line 318, in async_get_tts_audio
    message, language, options)
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/tts/google.py", line 83, in async_get_tts_audio
    token.calculate_token, part)
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/srv/homeassistant/lib/python3.6/site-packages/gtts_token/gtts_token.py", line 28, in calculate_token
    seed = self._get_token_key()
  File "/srv/homeassistant/lib/python3.6/site-packages/gtts_token/gtts_token.py", line 57, in _get_token_key
    tkk_expr = re.search(".*?(TKK=.*?;)W.*?", line).group(1)
AttributeError: 'NoneType' object has no attribute 'group'
Also for lovelace.
## Log Details (ERROR)
Thu Nov 29 2018 20:47:07 GMT+0700 (Indochina Time)
https://192.168.1.60:8123/frontend_latest/app-0fd67575.js:89:305 Uncaught TypeError: Cannot read property 'toUpperCase' of null
Thu Nov 29 2018 20:47:01 GMT+0700 (Indochina Time)
https://192.168.1.60:8123/frontend_latest/app-0fd67575.js:89:305 Uncaught TypeError: Cannot read property 'state' of undefined
Aha, thanks. Had the same issue of HA not showing the web-interface. Commenting out owntracks helped for now. Have to dig into the breaking change for owntracks, but at least HA is up and running again now.
I’m seeing the same errors.
17track is not working for me: [homeassistant.components.sensor.seventeentrack] Invalid username and password provided
Someone told me it’s related to the google calendar component… if you use it try to comment out that and restart…
No, I don’t even use Google Calendar.
I do use Owntracks and commented that out, but it won’t load the Lovelace fontend (and I can’t figure out how to disable Lovelace to go back to the old UI).
Hmm ok… so we must only wait for a fix… I was back to 0.82.1
Change “/lovelace” to “/states”
However it’s totally dead for me - starts up then just hangs -still running but nothing in the log - and that’s the chatty journalctl -fu [email protected] log file which stops after a short while.
The database upgrade went quickly and successfully
Downgrading to 0.82 hasn’t helped :sob:
(Removed a comment RE: Google Calendar - it’s called Google and doesn’t mention calendar)
Thanks, that did it :+1:t3:
Downgrading to 0.81.6 gives me trouble also now. Seems to have something to do with auth token, i have no idea what to do now. This error comes over and over again:
2018-11-29 15:33:07 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1706082512] Unexpected error inside websocket API
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/websocket_api/http.py", line 140, in async_handle
    connection = await auth.async_handle(msg)
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/websocket_api/auth.py", line 76, in async_handle
    msg['access_token'])
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/auth/__init__.py", line 362, in async_validate_access_token
    cast(str, unverif_claims.get('iss')))
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/auth/__init__.py", line 325, in async_get_refresh_token
    return await self._store.async_get_refresh_token(token_id)
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/auth/auth_store.py", line 190, in async_get_refresh_token
    await self._async_load()
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/auth/auth_store.py", line 247, in _async_load
    name=group_dict['name'],
KeyError: 'name'
Do you use owntracks? You have to change your owntracks config. It has moved from device_tracker: to its own component owntracks:. After this change, the web interface became up and running again (for me) after a restart of HA.
If you are using owntrack, its configuration has to be moved from device_tracker: to the root of configuration.yaml
for example:
device_tracker:
becomes
owntracks:
Hope this help. My UI was stuck too before I changed that
Commented Owntracks out and that made no difference.
Disabling all Device Trackers and it’s working. Now to narrow down the culprit…
Nope, but i use asuswrt, which has become it’s own component as well. It hasn’t been working since 0.81.6. I did move the settings back. Now i’ve upgraded to 0.83.0 again, but i have a failing “device tracker”, despite having the settings as they should (configuration.yaml):
asuswrt:
  host: 192.168.1.1
  username: !secret asuswrt_username
  password: !secret asuswrt_password
  protocol: telnet
From the logs:
2018-11-29 15:50:41 ERROR (MainThread) [homeassistant.setup] Error during setup of component asuswrt
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/setup.py", line 145, in _async_setup_component
    hass, processed_config)
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/asuswrt.py", line 57, in async_setup
    await api.connection.async_connect()
  File "/srv/homeassistant/lib/python3.6/site-packages/aioasuswrt/connection.py", line 100, in async_connect
    self._host, self._port)
  File "/usr/local/lib/python3.6/asyncio/streams.py", line 75, in open_connection
    lambda: protocol, host, port, **kwds)
  File "/usr/local/lib/python3.6/asyncio/base_events.py", line 777, in create_connection
    raise exceptions[0]
  File "/usr/local/lib/python3.6/asyncio/base_events.py", line 764, in create_connection
    yield from self.sock_connect(sock, address)
  File "/usr/local/lib/python3.6/asyncio/selector_events.py", line 451, in sock_connect
    return (yield from fut)
  File "/usr/local/lib/python3.6/asyncio/selector_events.py", line 481, in _sock_connect_cb
    raise OSError(err, 'Connect call failed %s' % (address,))
ConnectionRefusedError: [Errno 111] Connect call failed ('192.168.1.1', 22)
EDIT: Thought the OwnTracks post was for me. Still relevant though.
Have updated to 0.83 but HA does not load ?
Got it - had to remove the Bluetooth Tracker Too…
- platform: bluetooth_tracker
  request_rssi: true
  consider_home: 180
Now to work out what is flooding the logs with:-
Nov 29 15:02:19 haas hass[4241]: Traceback (most recent call last):
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/aiohttp/web_protocol.py", line 390, in start
Nov 29 15:02:19 haas hass[4241]:     resp = await self._request_handler(request)
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/aiohttp/web_app.py", line 366, in _handle
Nov 29 15:02:19 haas hass[4241]:     resp = await handler(request)
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/aiohttp/web_middlewares.py", line 106, in impl
Nov 29 15:02:19 haas hass[4241]:     return await handler(request)
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/static.py", line 66, in staticresource_middleware
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/real_ip.py", line 34, in real_ip_middleware
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/ban.py", line 66, in ban_middleware
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/auth.py", line 97, in auth_middleware
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/view.py", line 115, in handle
Nov 29 15:02:19 haas hass[4241]:     result = await result
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/api.py", line 220, in post
Nov 29 15:02:19 haas hass[4241]:     if not request['hass_user'].is_admin:
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/aiohttp/web_request.py", line 201, in __getitem__
Nov 29 15:02:19 haas hass[4241]:     return self._state[key]
Nov 29 15:02:19 haas hass[4241]: KeyError: 'hass_user'
@bachoo786 See above, probably OwnTracks or Asuswrt component that you have to change in your config.
