0.83: Fibaro Home Center Hubs, locks via voice, Traccar
Do you use owntracks? You have to change your owntracks config. It has moved from device_tracker: to its own component owntracks:. After this change, the web interface became up and running again (for me) after a restart of HA.
If you are using owntrack, its configuration has to be moved from device_tracker: to the root of configuration.yaml
for example:
device_tracker:
  - platform: owntrack
    max_gps_accuracy: 200
becomes
owntracks:
Hope this help. My UI was stuck too before I changed that
Commented Owntracks out and that made no difference.
Disabling all Device Trackers and it’s working. Now to narrow down the culprit…
Nope, but i use asuswrt, which has become it’s own component as well. It hasn’t been working since 0.81.6. I did move the settings back. Now i’ve upgraded to 0.83.0 again, but i have a failing “device tracker”, despite having the settings as they should (configuration.yaml):
asuswrt:
  host: 192.168.1.1
  username: !secret asuswrt_username
  password: !secret asuswrt_password
  protocol: telnet
From the logs:
2018-11-29 15:50:41 ERROR (MainThread) [homeassistant.setup] Error during setup of component asuswrt
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/setup.py", line 145, in _async_setup_component
    hass, processed_config)
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/asuswrt.py", line 57, in async_setup
    await api.connection.async_connect()
  File "/srv/homeassistant/lib/python3.6/site-packages/aioasuswrt/connection.py", line 100, in async_connect
    self._host, self._port)
  File "/usr/local/lib/python3.6/asyncio/streams.py", line 75, in open_connection
    lambda: protocol, host, port, **kwds)
  File "/usr/local/lib/python3.6/asyncio/base_events.py", line 777, in create_connection
    raise exceptions[0]
  File "/usr/local/lib/python3.6/asyncio/base_events.py", line 764, in create_connection
    yield from self.sock_connect(sock, address)
  File "/usr/local/lib/python3.6/asyncio/selector_events.py", line 451, in sock_connect
    return (yield from fut)
  File "/usr/local/lib/python3.6/asyncio/selector_events.py", line 481, in _sock_connect_cb
    raise OSError(err, 'Connect call failed %s' % (address,))
ConnectionRefusedError: [Errno 111] Connect call failed ('192.168.1.1', 22)
EDIT: Thought the OwnTracks post was for me. Still relevant though.
Have updated to 0.83 but HA does not load ?
Got it - had to remove the Bluetooth Tracker Too…
- platform: bluetooth_tracker
  request_rssi: true
  consider_home: 180
Now to work out what is flooding the logs with:-
Nov 29 15:02:19 haas hass[4241]: Traceback (most recent call last):
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/aiohttp/web_protocol.py", line 390, in start
Nov 29 15:02:19 haas hass[4241]:     resp = await self._request_handler(request)
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/aiohttp/web_app.py", line 366, in _handle
Nov 29 15:02:19 haas hass[4241]:     resp = await handler(request)
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/aiohttp/web_middlewares.py", line 106, in impl
Nov 29 15:02:19 haas hass[4241]:     return await handler(request)
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/static.py", line 66, in staticresource_middleware
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/real_ip.py", line 34, in real_ip_middleware
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/ban.py", line 66, in ban_middleware
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/auth.py", line 97, in auth_middleware
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/view.py", line 115, in handle
Nov 29 15:02:19 haas hass[4241]:     result = await result
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/api.py", line 220, in post
Nov 29 15:02:19 haas hass[4241]:     if not request['hass_user'].is_admin:
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/aiohttp/web_request.py", line 201, in __getitem__
Nov 29 15:02:19 haas hass[4241]:     return self._state[key]
Nov 29 15:02:19 haas hass[4241]: KeyError: 'hass_user'
@bachoo786 See above, probably OwnTracks or Asuswrt component that you have to change in your config.
Also anyone have problem with broadlink switch? I cannot control all my broadlink switch.
Ah, looks like it’s all my HTTP Sensors…
HASS is returning
<html><head><title>500 Internal Server Error</title></head>
<body><h1>500 Internal Server Error</h1>Server got itself in trouble</body></html>
Does anyone definitively know if the asuswrt component using SSH works in this release? I don’t want to upgrade if the asuswrt device tracker component is still broken.
And to clarify since the docs are pretty vague -
Do we just need to setup the asuswrt component and that will automatically start tracking devices or do we still need to add the asuswrt device tracker config to the "device_tracker: " section?
Assuming it’s the former then if I have a asuswrt device tracker set up then do I need to remove that config entry?
Nope I don’t have any of those components in my config.
It’s been over an hour now it’s not working.
Telnet port is 23. Add port: 23 into the configuration.
I’ve stuck on loading 0.83 but after i read to remove OwnTracks in config i finally got it HA working again.
I am having the following errors:
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 343, in _async_add_entity
    raise HomeAssistantError(msg)
homeassistant.exceptions.HomeAssistantError: Entity id already exists: group.all_switches
2018-11-29 15:55:41 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
Same here. I actually forgot I had it enabled since I don’t use it anymore. Everything seemed to come up just fine, but the UI wasn’t loading. There wasn’t anything apparent in the logs at the warn level either. I saw this thread, removed the config, restarted the container, and everything came up as expected.
@touliloup,
Does the Google Home Bluetooth tracker works for Google Home Mini?
I don’t know, I believe it does but I haven’t tested with one.
I think it does. I went to http://[My Google Home Mini IP]:8008/setup/eureka_info and I see a bunch of info.
That did the trick :smiley:
EDIT: only 10 mins of joy, back to troubleshooting.
Anyone here care to explain why we need this “config entry” stuff?
For me it looks like it just makes everything more complicated and less comfortable. I just do not find a way to store my config in a version controll system anymore with this.
