0.83: Fibaro Home Center Hubs, locks via voice, Traccar
Ah, looks like it’s all my HTTP Sensors…
HASS is returning
<html><head><title>500 Internal Server Error</title></head>
<body><h1>500 Internal Server Error</h1>Server got itself in trouble</body></html>
Does anyone definitively know if the asuswrt component using SSH works in this release? I don’t want to upgrade if the asuswrt device tracker component is still broken.
And to clarify since the docs are pretty vague -
Do we just need to setup the asuswrt component and that will automatically start tracking devices or do we still need to add the asuswrt device tracker config to the "device_tracker: " section?
Assuming it’s the former then if I have a asuswrt device tracker set up then do I need to remove that config entry?
Nope I don’t have any of those components in my config.
It’s been over an hour now it’s not working.
Telnet port is 23. Add port: 23 into the configuration.
I’ve stuck on loading 0.83 but after i read to remove OwnTracks in config i finally got it HA working again.
I am having the following errors:
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 343, in _async_add_entity
    raise HomeAssistantError(msg)
homeassistant.exceptions.HomeAssistantError: Entity id already exists: group.all_switches
2018-11-29 15:55:41 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
Same here. I actually forgot I had it enabled since I don’t use it anymore. Everything seemed to come up just fine, but the UI wasn’t loading. There wasn’t anything apparent in the logs at the warn level either. I saw this thread, removed the config, restarted the container, and everything came up as expected.
@touliloup,
Does the Google Home Bluetooth tracker works for Google Home Mini?
I don’t know, I believe it does but I haven’t tested with one.
I think it does. I went to http://[My Google Home Mini IP]:8008/setup/eureka_info and I see a bunch of info.
That did the trick :smiley:
EDIT: only 10 mins of joy, back to troubleshooting.
Anyone here care to explain why we need this “config entry” stuff?
For me it looks like it just makes everything more complicated and less comfortable. I just do not find a way to store my config in a version controll system anymore with this.
So newbies can run through a setup wizard and configure everything - no need for SSH/Samba etc. Supposadly easy to do sensible migrations so OwnTracks changing doesn’t break load of installs
Is a pain to backup/disable if stuff goes wrong.
This needs a good solution… I run home assistant as docker container for a reason and i really like a “fallback” when i mess up my config… And i ocassionally do
Short joy, after approx 10 minutes, all devices were apparently away, and also the upload/download sensor seems to fail, spamming my log:
2018-11-29 18:23:28 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.asuswrt_download fails
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 221, in async_update_ha_state
    await self.async_device_update()
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 347, in async_device_update
    await self.async_update()
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/sensor/asuswrt.py", line 106, in async_update
    await super().async_update()
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/sensor/asuswrt.py", line 54, in async_update
    self._speed = await self._api.async_get_current_transfer_rates()
  File "/srv/homeassistant/lib/python3.6/site-packages/aioasuswrt/asuswrt.py", line 217, in async_get_current_transfer_rates
    self._rx_latest = data[0]
IndexError: list index out of range
2018-11-29 18:23:28 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.asuswrt_upload_speed fails
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/sensor/asuswrt.py", line 88, in async_update
Has anyone managed to make the downgrade work? When I go back to version 0.82.1 it does not work.
HTTP Sensors are broke at 0.83 apparently. https://github.com/home-assistant/home-assistant/pull/18733
A fix has been added to the queue of stuff in 0.83.1
Anyone know if it’s possible to switch to the Long Lived Tokens on HTTP Sensors and if they work?
asuswrt broken for me too.
Im getting the same error and i have the same router.
upgraded to 0.83 and now HA will not start. Seeing this in the logs. Any ideas?
2018-11-29 11:48:15 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 390, in start
    resp = await self._request_handler(request)
  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_app.py", line 366, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_middlewares.py", line 106, in impl
    return await handler(request)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/static.py", line 66, in staticresource_middleware
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/real_ip.py", line 34, in real_ip_middleware
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/ban.py", line 66, in ban_middleware
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/auth.py", line 97, in auth_middleware
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/view.py", line 115, in handle
    result = await result
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/api.py", line 85, in get
    if not request['hass_user'].is_admin:
  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_request.py", line 201, in __getitem__
    return self._state[key]
KeyError: 'hass_user'
yes you are right. i was using telnet too. I have changed it to SSH and port 22. It seems to be working now.
