TimeShit is the same as RecoveryPoint in Windows. It rool back to earlier wersion if something happen. Its standard now in Ubuntu. Can be used both with GUI and command line
Read lot of complaints, but my upgrade went perfectly smooth (from 0.82.1 0.83.1). Fixed before upgrading 2 breaking changes, and zero errors from the upgrade.
There’s a breaking change for Owntracks according to the docs. It this only true when using the http mode in Owntracks - or does this also apply for MQTT?
Just upgraded to 83.1
It takes a looong time starting, and the log contains many,many of these errors:
2018-11-30 12:19:35 WARNING (Recorder) [homeassistant.components.recorder.migration] Database is about to upgrade. Schema version: 6
2018-11-30 12:19:45 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2018-11-30 12:23:51 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (_mysql_exceptions.OperationalError) (1034, “Index for table ‘states’ is corrupt; try to repair it”) [SQL: ‘CREATE INDEX ix_states_entity_id ON states (entity_id)’] (Background on this error at: http://sqlalche.me/e/e3q8)
Finally hassio starts, but is unable to use recorder and it’s depentants.
For recorder, I’m using MariaDB on another server.
version 82.1 worked fine.
What can I do?
Woody, did you get this to work? My node red connection broke too. I have updated to 0.83.1 and it still does not work. My log is flooded with the following every few seconds.
Login attempt or request with invalid authentication from XXX.XX.X.X
Also my user list is missing and when I try to recreate users it says I am not authorized.
which obviously doesn’t work. The plex sensor is great, but it’s a little slow. Was hoping that this could speed things up a bit. (Have also tried using the mqtt notification within tautulli but that doesn’t support mqtt via ssl).
