After updating to 0.86 my notifications not working. Got this error message:
`Invalid config for [automation]: Service notify.TELEGRAM does not match format <domain>.<name> for dictionary value @ data['action'][0]['service']. Got None. (See /config/configuration.yaml, line 138). Please check the docs at https://home-assistant.io/components/automation/`
This is how my action is configured in the automations.yaml file:
- service: notify.TELEGRAM
message: ALARM WURDE AUSGELÖST!!!
all of your yaml files should be in lower case. The one exception is when a state has a capital. There is a difference between on and On when automations are checking the state.
I’m having the same issue after updating with Pushbullet. Although doing lower case hasn’t helped. I will retry again from scratch and see if it works. Definitely wasn’t an issue before 0.86.
service: notify.(TELEGRAM)–>this is my bot name with telegram don´t go
I have returned to 0.84.1 and all it is OK as before
With no indication that capitals are unacceptable and that this won’t actually work. the error message sent me looking in the wrong place, too: this has nothing to do with the <domain>.<name> format.
