0.87.1 Update breaks sensors?
Can’t you just rename it?
Maybee I misunderstod but I changed all the names for the switch to port…
group:
  garage_door:
    view: no
    control: hidden
    icon: mdi:garage
    entities:
      - cover.sonoff_sv_garage
      - switch.port
switch:
###  Garage Switch     ###
    switches:
      port:
        value_template: "{{ is_state('cover.sonoff_sv_garage', 'open') }}"
        turn_on:
          service: cover.close_cover
            entity_id: cover.sonoff_sv_garage
        turn_off:
          service: cover.open_cover
        icon_template: >-
          {% if is_state('cover.sonoff_sv_garage', 'open') %}
            mdi:garage-open
          {% else %}
            mdi:garage
          {% endif %}
I think its all related to the customize settings?
I have always had this to hidden
customize:
sensor.nina_ipad_battery_level:
hidden: true
sensor.nina_ipad_battery_state:
hidden: true
but now they are shown again even if they are supposed to be hidden
and the same for the garage port customize setting
cover.sonoff_sv_garage:
  device_class: garage
  homebridge_cover_type: garage_door
  friendly_name: Garageport
for some reason this dosent work anymore?
could this be a lovelace issue?
no - lovelace only changes how things are displayed
Hi David
Sorry but then it must mean that the customize settings is broken?
the sensor name is the same as always:
And the customize settings are correct
  customize:
    # Add an entry for each entity that you want to overwrite.
      hidden: true
      hidden: true
Same goes for the cover icon on the garage door?
Also I read some of your post and I am really confused isn’t lovelace the new standard?
what’s this storage mode? so far I have just kept it as is and kept upgrading it.
I can see in my string that I am now using the lovelace as default (No changes from me)
So this should be ok?
I now we are in a transition but it its very hard to find out how to fix things? :neutral_face:
especially when things worked perfectly and then they dont
Any help you can provide is greatly appreciated
Lovelace will ignore hidden: true. In lovelace if you don’t want to see something, don’t add it to the card. If you have not ‘taken control’ of lovelace, it will use an autogenerated mode which will mimic old groups etc (but still will ignore hidden: true)
At some point, when you click on edit UI (3 dots top right) you take control and then you move from autogenerated to storage mode in lovelace and it will only show what you add to cards. Everything else will be hidden.
Hope that makes sense.
@DavidFW1960 So you’re telling me that I have to take control in order to Hide stuff, because the autogenerated mode is not working with the Hide rules in the customize group?
So taking the plunge is there a easy way to fix this in the editor
Basically remove or hide “Badges” I dont want top row
And changing the MDI to get back to the Icon that would change when openeing and closing the garagedoor?
I think this would give me a good start to fix the rest by hand.
Just got HAromey remote back online JUHU!
UPDATE:
Ended up just deleting the lines in the config I didnt want
But the MDI for the garageport is still eluding med?
