Seems like every update I do lately breaks my setup?
Just got false positive on the garage door - scary stuf when your not home!
Running latest version 0.87.1
What should I do?
What should I do?
Any warning/error messages in Home Assistant’s log?
Can you post the configuration of one or two of the affected binary_sensors?
My guess is there may be an invalid option specified. Version 0.87.X no longer ignores invalid options but will identify and complain about them (and refuse to register the entity).
Just tried to do a validate after updating and I get allot of errors now (I had 0 before)
This must be a major release update?
customize:
# Add an entry for each entity that you want to overwrite.
binary_sensor.garagedoor:
friendly_name: Garage Door
house_sensors:
control: hidden
entities:
- binary_sensor.main_door
- binary_sensor.back_door
- binary_sensor.main_door2
- binary_sensor.garagedoor
# Automations notification for Garage door open if Nobodys home
- alias: Garagedoor
hide_entity: true
initial_state: 'on'
- platform: state
entity_id: binary_sensor.garagedoor
to: 'on'
# Only when the adults are not home <--
condition:
- condition: and
conditions:
- condition: state
entity_id: sensor.henrik_presence
state: 'not_home'
- condition: and
conditions:
- condition: state
entity_id: sensor.nina_presence
state: 'not_home'
# Comment above lines out to enable garagedoor notification ALWAYS <--
- service: notify.ios_group_caspersen_home
message: "Garagedøren er åben? {{ states('sensor.time') }}"
title: "Home Assistant"
The error message identifies the source of the problem. Several of you binary_sensors are configured with an invalid option. optimistic
is not a valid configuration variable for an MQTT Binary Sensor.
Prior to 0.87, Home Assistant would ignore invalid options but not any more. See the last item in Breaking Changes.
MQTT platforms will now flag mistyped configs from
configuration.yaml
correctly as invalid, instead of just ignoring them. (@emontnemery - #20562) (mqtt docs) (breaking change)
But they are all set to false?
and according to the guide (At that point in time anyway)
So do I just delete all these lines?
cover:
Yes, delete them. There’s no such thing as optimistic
mode for a binary_sensor. It is typically available for components that can transmit commands, like MQTT Cover.
And that shouldnt affect funtionality?
I also get error on RETAIN? but I think I need them for it to remember previous state?
# Sonoff switches
- platform: mqtt
command_topic: "cmnd/Sonoff_B1/power"
state_topic: "stat/Sonoff_B1/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
Please explain how adding an invalid option to a component’s configuration can improve its functionality? It’s invalid and unused by the component.
For which entity? If you specified retain
for an MQTT component that publishes nothing, like a binary_sensor, then Home Assistant 0.87 will identify it as an error. Check the binary_sensor’s documentation, there’s no retain
option.
@123 and thanks for taking the time to help me!
retain: false
Found them in allot of places
Okay for some reason I dont get the line numbering on the errors anymore so its hard to find what needs to be changes
Reading the links it looks like ratin is ok for switches…so most be for all the others
MQTT Switch publishes messages to a topic (via command_topic
) therefore it makes sense this component offers the retain
option (although there are valid reasons for setting this to retain: false
which happens to be the default setting).
Ok so it should be enough to remove this from binary sensors
binary_sensor:
# RF Motion sensor
- platform: mqtt
state_topic: "tele/RF_Bridge1/RESULT"
value_template: '{{value_json.RfReceived.Data}}'
payload_on: ''
payload_off: ''
device_class: motion
qos: 1
# retain: false
just removed from every binary sensor and I got “Configuration valid!”
so everything should be back up and running after a reboot
Thanks for your help!
last question I promise!
the switch for the garageport now changed after the removal, and now it looks like this
but I still have my:
cover.sonoff_sv_garage:
device_class: garage
homebridge_cover_type: garage_door
friendly_name: Garageport
Could this be related to another change, and not the removal of retain & optimistic
I can’t make sense of this:
Please post the entire formatted configuration for the cover. Is the cover’s friendly_name
in the customize.yaml
file?
no I have everything in the configuration yaml file
customize:
# Garageport switch DIY
cover:
- platform: mqtt
name: "Sonoff SV Garage"
state_topic: "cmnd/garagestate/POWER2"
command_topic: "cmnd/Sonoff_SV_Garage/POWER"
payload_open: "ON"
payload_close: "ON"
payload_stop: "ON"
state_open: "ON"
state_closed: "OFF"
### Garage Switch ###
switches:
garage:
value_template: "{{ is_state('cover.sonoff_sv_garage', 'open') }}"
turn_on:
service: cover.close_cover
entity_id: cover.sonoff_sv_garage
turn_off:
service: cover.open_cover
icon_template: >-
{% if is_state('cover.sonoff_sv_garage', 'open') %}
mdi:garage-open
{% else %}
mdi:garage
{% endif %}
group:
garage_door:
view: no
control: hidden
icon: mdi:garage
entities:
- cover.sonoff_sv_garage
- switch.garage
That should be everything, and some notification on the state
That’s a weird configuration.
You have a group, that includes both the cover and a template switch, that uses the cover to provide the switch. Why?
According to documentation retain and optimistic are still available for cover MQTT.
I’m confused by your setup
I made a switch for the garageport and also created the “real” garage function in home assistant.
- switch.garage
The switch was needed to get it working as a switch in google assistant or Siri - can’t remember
Is this a problem?
Its not different than having all the switches defined as both switches and lights
Its still there
So wouldnt the friendly name be changed by:
customize:
Google assistant sees covers just fine.
I don’t know if it’s a problem but it seems like redundant work for no benefit
Any input to why Home assistant dosent see it as Garage port?
Deleting the switch dosent solve it…
And for some reason it ignores the:
customize:
The icon worked before showing open and closed correctly?
This update really calls for many changes
