0.88.0 Warning about valid (required) key senders in platform: imap_email_content
I get the waring
Your configuration contains extra keys that the platform does not support. Please remove [senders]. (See /config/sensor.yaml, line 0).
The configuration looks following:
  • platform: imap_email_content
    server: imap.gmail.com
    port: 993
    username: !secret email_address
    password: !secret email_password
    value_template: “{{ subject | replace(‘Alarm - ‘,’’) }}”
    senders:
(there is -, not sure why this web site is replacing it with a bullet symbol)
It complains about the senders key, but it is mandatory for the sensor.
I have the coming warning but can not find the extra key I should delete:
Your configuration contains extra keys that the platform does not support. Please find and remove the following:
[icon_template]. (See /config/sensor/syteme.yaml, line 32).
- platform: command_line
  scan_interval: 60
  unit_of_measurement: °C
  icon_template: mdi:thermometer
  command: >-
    if [ -e /sys/class/thermal/thermal_zone0/temp ]
      then cat /sys/class/thermal/thermal_zone0/temp
    fi
  value_template: >-
    {% if value != '' %}
      {{ value | multiply(0.001) | round }}
    {% else %}
      unknown
    {% endif %}
Does someone know how to ?
Thanks.
88.1 fixes it, already created an issue on github for that?
Looking at the documentation https://www.home-assistant.io/components/sensor.command_line/, the sensor does define the icon_template configuration variable (which is what the error says).
Got it, thanks.
